Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 04-28-2005, 07:24 AM
69lincolnmarkiii 69lincolnmarkiii is offline
3.5 stalls when stopping
I have a 1994 Chrsyler LHS 3.5. It stalls once it warms up and you come to a stop. It also has a little bit of a ruff idel just sitting still when you start it. It always starts back up but sometimes cranks longer then it should.
I have replaced both the Cam and crank postion sensors and also the spark plugs. No effect. Fuel pressure regulator seems to be fine and does not leak into the vacume port. Anyone have any ideas here?
failing fuel pump?
fuel filter?
injectors?
plug wires?
IAC motor?
Also head gaskets are still good.
Old 04-28-2005, 02:35 PM
kcg795 kcg795 is offline
Re: 3.5 stalls when stopping
My mom's 3.3 in her 93 does this too. It only does it once and a while, though, and hasn't done it in a long time. I have no idea what the deal is. I replaced the spark plugs, PCV valve, and we had the plug wires changed. Runs smoother, but still has that fit now and then. A lot of times, when we'd floor it, it'll spew out black smoke. I usually take advantage of this when a white car decides to tailgate me.
Old 04-28-2005, 06:05 PM
Bizzy102 Bizzy102 is offline
Your tourpue converter could be locking up on you when you come down to a stop. How old is your trans, how many miles on the car, does it happene more hot then cold or vise versa.
Old 04-29-2005, 12:41 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
hey, didn't you post this in the Dodge Intrepid, and Chrysler LHS forum?
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 04-29-2005, 10:25 AM
SOLUTION************************
It ended up being the stupid pointless EGR valve! Thanks for all your help.
(I was not getting much help in the LHS forum)
