Old 04-27-2005, 11:26 PM
roids87 roids87 is offline
Send a message via AIM to roids87
Briding my subs down
How can i go about bridging my 2 Rockford p2 12" 8 ohm subs down to 4 ohms each on a kenwood 800w 2 channel amp?
Old 04-27-2005, 11:34 PM
Diceman83's Avatar
Diceman83 Diceman83 is offline
Send a message via AIM to Diceman83
Re: Briding my subs down
Can we have a little more info?
Namely:
Are the subs dual voice coil?
Is the amp 2 ohm stable on each channel?
How do you have them wired now?
Old 04-28-2005, 12:02 AM
No subs arn't dual voice coil, yes amp is 2ohm stable on each channel, they are waiting to be installed.
Old 04-28-2005, 12:08 AM
Diceman83's Avatar
wait, you're saying that the RFs are 8 ohms in a single coil?? I didn't think they sold them like that. If they are, the thing to do is wire them in parallel to the amp, bridged across the two channels (both positives connected to the outside positive, and both negatives connected to the outside negative). That will give the amp a bridged 4 ohm load.
There is no way to "bridge your subs down to 4 ohms each", a 8 ohm sub is an 8 ohm sub and can't be changed.
Old 04-28-2005, 12:46 AM
Yea they make a single coiled 8ohm sub.
http://www.rockfordfosgate.com/produ...h%20Subwoofers
and thanks for the help
Old 04-28-2005, 06:05 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
but make sure your amp can be bridged before you go off trying to bridge it...not all amps can be bridged
