Old 04-27-2005, 09:07 PM
joosdawg joosdawg is offline
Send a message via AIM to joosdawg
boost gauge is leaking!!WTF
so i installed my boost gauge and had it on my dash for a week until i got my gauge pod in, so i go to pick it up and the boost line going into the back of the gauge falls out lol. so i stuck it back and and both sides of the fittings(the hose and the gauge) have teflon tape threaded on them. after my install idle vaccum shows about 12-14 and makes a hissing noise so i took it out and threw on some JB weld and let it sit for a good 2 hours i started driving and it was back to normal for about 5 min then it busted a leak again. my question is, is my little crown thing in the fitting the wrong way? i have a faze gauge btw(dont tell me that was my mistake ) is there a diagram to install the stupid hose correctly? because mine seems to ultra suck. -Ryan
Old 04-27-2005, 09:16 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: boost gauge is leaking!!WTF
what kind of fitting is it? if its just a barbed fitting that you slide the hose over you may need to use a hose clamp to hold it tight
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-27-2005, 09:55 PM
no its not a barbed fitting its like this
Old 04-27-2005, 09:59 PM
milton666's Avatar
milton666 milton666 is offline
Send a message via MSN to milton666
is your plastic boost line going all the way through the "crown thing" or is it just stuck in there? i put mine through it cuz when you screw everything together it crimps that "crown thing" and holds everything tight.
95' Gs-t (broke the fuck down...)
68' Mustang getting reassembled right now, 82.763% done
http://www.tagworld.com/milton666
Old 04-27-2005, 10:34 PM
i put the boost line through the crown but now that i think about it i only tightened it hand tight am i supposed to wrench it on? if so i feel like an idiot
Old 04-28-2005, 08:01 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
On mine, the "crown thing" you are referring to is a compression fitting. You will probably need to get a new one at the hardware store. But your's might be different. Yes, you do need to tighten it down with a wrench to compress the fitting.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-28-2005, 09:57 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
yeah, you have to sench that thing on tight! when i installed my autometer boost gauge i couldntt for the life of me figure out how the tube stayed in place. tighten the thing as tight as you can with a wrench and you seal it up..
DSM geek
Old 04-28-2005, 10:13 AM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Also, quit using the shitty plastic tube!!
That goes for all of ya.
Kris
2012 Genesis Coupe 2.0t
Old 04-28-2005, 11:25 AM
Re: Re: boost gauge is leaking!!WTF
Are you talking about the small diameter hard plastic tube you get with the boost gauge? If so, what should we use instead, and why?
1997 Spyder GS-T
5-Speed
Old 04-29-2005, 12:10 AM
Nayr747's Avatar
Nayr747 Nayr747 is offline
Yeah why?
I have an Autometer boost gauge and I didn't have to wrench it down. I just tightened it with my hand annd it's fine. The picture you drew looks like half a compression fitting. At least on mine it has a tapered end on both sides. You could try cutting off the end of your hose to make sure that its not causing the problem and try again with the newly cut end.
'99 GSX, 5-speed, 60k miles: Greddy filter / RRE uicp / 1g bov / Autometer boost gauge / Injen-copy intake / Megan DP (not installed)
Coming soon! Thx to Blackcrow & nova1313! http://dsm-one.org/
Adopt pets in need! http://www.petfinder.com/
Old 04-29-2005, 06:41 AM
kjewer1 kjewer1 is offline
AF - Advisor
You defintely should be using a wrench on a compression fitting. You should not however be tightening down as hard as you can. Just snug. You want to just drive that ferrule into the tubing enough to create a seal, but not enough to noticeably reduce the inside diameter. This is why many 1/8th inch tubing applications will use metal inserts, to preserve the tubings inside diameter.
If its leaking, buy a new ferrule at a local hardware store. Several near me carry 1/8th inch parts. Cut the tube to get a fresh end on it, install the nut, the ferrule, and try again. Make sure you are holding the tube into the connector as you tighten so it doesnt get squeezed out.
If the guage has an NPT type fitting on the back and a compression fitting adapter, I would go to a hard tubing dosconnect like the one shown on my site. Some poeple swap to a hose barb and run soft tubing. If its a compression fitting built right into the guage, you have no choice but to use that.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-29-2005, 07:21 AM
I sure did. THe stock plastic gauge line was cracked from the get-go so I went to the rubber line. Rubber will become brittle over time, but I never have to worry about the plastic getting near something hot under the hood near the T or kinking.
Kris
Old 04-29-2005, 07:35 AM
AF - Advisor
If you look on mcmaster.com or similar there are other materials used in making the vac tubing. Some might be better suited to our application, but no one bothers to look into it or try anything new. I like the nylon tubing, but it can break with time. Mine has lasted 5 years so far. Copper will also fatigue from motor movement. Oh well.
Kevin Jewer
Old 04-30-2005, 03:12 AM
Nayr747's Avatar
I used those quick disconnect fittings on my paintball gun with what they call "macro line" which is kind of like oversized boost gauge hose. A lot of people use it and it works fine but with me it leaked big time. I switched back to my stock ss line and no leaks. I think my problem was that the hose had to curve pretty sharp right after it came out of the fitting so it might have created a little space for air.
Old 04-30-2005, 09:28 AM
AF - Advisor
I have seen those fittings. A sharp curve can cause problems, that line is stiff. The trick is in angling the fittings strategically, but its not always possible with all the different parts and configurations out there. Luckily for the cars, and industrial equipment, this is rarely a problem.
Just a side note, everyone else in the POSR group has moved on to paintball without me I'm the last asshole left struggling with these POS cars.
Kevin Jewer
