Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 04-27-2005, 08:51 PM
H.O.Rider H.O.Rider is offline
Rough Idle - 96 GMC 5.7 (fuel inj. cleaning??)
I have a 96 GMC Sierra SLT with a 5.7l Vortec.
110000 miles. It has new plugs, wires, cap and
rotor, all of which made it run much stronger.
Still idles a little rough. I was thinking of having the
fuel inj system cleaned. Anyone have this help a rough idle
or any other suggestion?? Never gets a check engine light.
Thanks
Old 04-28-2005, 10:16 AM
MyTOY's Avatar
MyTOY MyTOY is offline
Most in this forum are more knowlegeable than I, but I can
tell you changing my fuel filter was real easy on my 97. I also ran some
injector cleaner through it and is running great. I've seen alot
of suggestions on rough idle. Some look for vacuum/gasket leak.
Some suspect the fuel regulator (especially if it hesitates to start
when warm) Some have had a worn shaft thing in the distributor.
Air filter (I put in a K&N air filter and it seems my milage has
improved a bit.) I have seen people suspect the MAF sensor.
people have suggested going to a shop that can read the GM
codes on the computer before condemning injectors and such.
Apparently, checking the fuel pressure is easy with the right tool.
I see alot of folks replacing 02 sensors.
Just some thoughts.
Old 04-28-2005, 06:44 PM
Thanks for the info. I have recently installed a new fuel pump(1 year ago), changed the fuel filter, pcv valve, intake gaskets about a year ago
etc..
I am really curious if anyone cleared up a slightly rough idle with a
fuel injection service??
Thanks
