Go Back   Automotive Forums Car Chat > Toyota > Pick-Up
Old 04-27-2005, 07:56 PM
Drag it Drag it is offline
V8 into the ole 83
SOme guy has a "like-new" 83 short box.
He wants a whoping $150 for it.
I want to know if a chevy v8 swap has been done on these
trucks and how hard it would be to accomplish.
I know from 84 on it is common, but this is the last year of this bodystyle.
Thanks.
Old 06-27-2005, 03:43 PM
ndoerr ndoerr is offline
Re: V8 into the ole 83
yeah i thought about it on my 1980 yota, and did it. i put a '75 Le Mans 350 in it. it took some "custom" motor mounts and "custom" body work to fit the beast in but it works
Old 06-28-2005, 10:48 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Been done. Advance Adapters has everything you need. What tranny will you use ? The Toy tranny (esp the 83 POS tranny) won't handle a V8.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 06-28-2005, 12:20 PM
corbinwaterski's Avatar
corbinwaterski corbinwaterski is offline
You'll need the W56 or W56D. It a good solid tranny. Look over on http://board.marlincrawler.com/index...918&board=14.0
to read up on a bunch of conversions.
WAR UTAH!!
Old 06-28-2005, 03:28 PM
ECVcrawltoy711 ECVcrawltoy711 is offline
i still woulnd run a toy tranny behind a v8. it will break just a matter of time
DRew
Old 07-07-2005, 05:28 PM
i was going to use a th-350 for a tranny
Old 07-08-2005, 09:13 AM
fourwd1's Avatar
AF -Advisor
700R4 would be better.
Lower 1st gearing and O/D.
89 4Runner - stock
Old 07-10-2005, 07:47 PM
700-r4 are weaker
Old 07-13-2005, 01:06 PM
wilwith1l's Avatar
wilwith1l wilwith1l is offline
Turbo 350 and 700R4 are almost identical transmissions. The ratios are the only real differance, as the 700R is made for highway and top speed. They are equal in strength. The 350 as a manual cable, where the 700 is like a Turbo 400.
Old 07-15-2005, 03:50 AM
the internals of a 400 are stronger than a 350...
But 90% of the tranny shops you talk to would recommend the th-350 for performance.
We had a tranny shop build a 700r4 and the first run in the 1968 chevy with a mildly built 327 ripped it to shred... totaly grenaded the tranny. Im talking parts inside of the tranny.. not the clutchs.
My 1970 firebird with a mildly build 396 has a 400 backing it up... my 1988 chevy truck has a 400 behind it... and my s10 will have a th-350.
