Old 04-07-2002, 03:03 PM
hiro's Avatar
hiro hiro is offline
Polishing problem
What do you guys use to apply compound? I've tried everything, really soft t-shirt, even the cloth that came with Tamiya wax.. but everything left scratch marks. Am I using too much force? Keep polishing longer? Get another cloth for polish?
Jenny
Old 04-07-2002, 03:30 PM
pkw1's Avatar
pkw1 pkw1 is offline
maybe you're pressing too hard... I just use an old cotton T, and it works great. I'm going to try using wax next with my kits, then clear coating.
All projects stalled...
Need to settle in on my new job, and don't have time to built models just yet.
Old 04-07-2002, 04:29 PM
modelfan1's Avatar
modelfan1 modelfan1 is offline
Send a message via AIM to modelfan1 Send a message via Yahoo to modelfan1
Are you using rubbing compound or polishing compound ?
Is the paint is still soft ? Is it enamel ?
I doubt if the clear coat will stick to the waxed surface !
Mike
Old age and treachery will overcome youthful exuberance everytime !!
Old 04-07-2002, 05:28 PM
daggerlee's Avatar
What's the difference between rubbing and polishing compound??
Dan
Old 04-07-2002, 05:36 PM
primera man's Avatar
"P-Man"
Re: Polishing problem
Maybe your not waiting for the paint to harden long enough.
I use the cloth that comes with the Tamiya Wax and have no problems.
Do you wash the cloth out?
It will hold any small(tiny) bits of plastic etc in the cloth that maybe getting left on the cloth and marking the marks on the model.
View All My Models Here.
Old 04-07-2002, 05:44 PM
modelfan1's Avatar
Rubbing compound is more abrasive than polishing compound and is usually dk brown and polishing compound is off white :bandit:
Mike
Old 04-07-2002, 05:52 PM
nikanora nikanora is offline
Send a message via AIM to nikanora
I had a very similar question that i was about to post...but now i don't
What should he use, polishing or rubbing? because i was going to buy some rubbing compound but i also saw polishing compound as well, so i held off on buying it.
Nika
Old 04-07-2002, 06:23 PM
modelfan1's Avatar
Rubbing compound is VERY abrasive and will remove layers of paint,you should'nt need that for a model. It's as abrasive as a powdered household cleanser like Comet.
Polishing compound has a much finer grit but will still remove paint.
Depending on how much work the paint needs you should invest in a polishing kit with varying grits of abrasive cloth,starting at 1000 grit and going to 12000 grit progressively and they should include a liquid polish
that would be finer than the finest abrasive cloth in the kit !
If you want,some automotive cleaner/waxes could be used,but keep in mind a "polish" is abrasive and will remove paint while a "wax"won't.
Always use a damp applicator to rub the polish or wax in and wash it out frequently because it will pick up all the material you're removing!
:bandit:
Mike
Old 04-07-2002, 08:03 PM
daggerlee's Avatar
Be careful with those polishing kits...I'm still trying to get a good finish with mine.
In the meantime, polishing compound can provide good results, just look at Guiddy's models...
Dan
Old 04-07-2002, 08:56 PM
"P-Man"
The Tamiya rubbing/polishing compound followed by Tamiya wax is all you should need to polish a model
Old 04-08-2002, 01:43 AM
hiro's Avatar
Thanks for the help!! I'm using Tamiya compound on TS paint, but using a dry cloth..I guess I'll try damp cloth and less pressure.
Jenny
Old 04-08-2002, 05:27 AM
pkw1's Avatar
I'm using the Tamiya Rubbing Compound.
I accidently rubbed too hard and took out a little corner of paint on my blue WRX I'll have to fix that up sometime...
Old 04-08-2002, 05:29 AM
pkw1's Avatar
Also, I'll be covering the entire hood of my Spoon ITR with carbon decal, so I'd like to clear coat the hood, so it looks shiny.. but I'll be doing some tests on something else 1st so I don't mess up the expensive Modelers CF decals.
Old 04-12-2002, 02:02 AM
tenzoracerevovii tenzoracerevovii is offline
i don't know.......the rubbing/polishing compound from Tamiya doesn't seem all that harsh.......i polished my mugen ITR after leaving the paint for 2 days (just wanted to test the compound) and it came out very nice.......i painted it pearl white and the pearl just gleams.........you can tell the difference a lot!.....i just use a dry cotton shirt like the others...works fine for me....
i have type-r stickers on my bike, will it go faster?
-me
Don't you know, it's 10 hp for every sticker, 50 hp extra for every additional inch of rear spoiler behond stock height.
-obiewancoyote
Polished Valve Cover for sale Axelthered05 Classifieds 0 06-22-2009 02:09 PM
98 pathy fuel gauge problem akaesha Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-28-2009 08:35 PM
96 Skylark starting problem mlb55 Skylark 0 03-14-2009 12:13 PM
E 150 Starter problem NIck86 Econoline 3 03-12-2009 07:38 AM
Polishing Problems GTRRR Car Modeling 5 10-04-2002 08:23 PM
