Old 04-27-2005, 06:51 PM
loonieymike loonieymike is offline
couple questions from a new guy
got a 1990 silverado given to me but it has some problems.
first- the oil filter adapter seems to be leaking. can i get rid of it and put the filter right on the block?
second- it seems to lose all lights in the rear only when i turn the head lights on. brake lights and signal lights. they work fine until i turn on the head lights.
third-it seems to lose major power when the hea lights are turned on.even while parked you can rev it right up then when the headlights are on it hesitates while reving.
four- seems very hesitant on take off
could most of the electrical problems be a bad ground?
please let me know about the oil filter asap thanks in advance
Old 04-27-2005, 06:55 PM
big_blue_chevy2006 big_blue_chevy2006 is offline
Send a message via MSN to big_blue_chevy2006 Send a message via Yahoo to big_blue_chevy2006
Re: couple questions from a new guy
on the oil filter thing wut that is is a oil cooler, u can take it off but i prolly wouldnt i mean itd be ok without im running mine without one at the moment till i can find a new gasket bc autozone n advancedont carry it.
Old 04-27-2005, 07:19 PM
yes its an oil cooler. the cooler part is missing on my truck.it only has one line going from the top to the bottom so i figured i could just eliminate it all together
Old 04-27-2005, 07:44 PM
id say go for it, some oil mightdripout of ur radiator tho so dont be suprised
Old 04-27-2005, 08:03 PM
Re: Re: couple questions from a new guy
why would oil drip out of the rad? there are no lines going to it. the line comes out of the adapter then loops around back to the other fitting.its not hooked to anything but itself.thats why i just want to eliminate it
Old 04-27-2005, 08:19 PM
hmm thas weird wellon my 90 chevy they went outta the cooler into the radiateroutta the radiater and backin to the cooler, well jus goforit and see wut its like itll prolly work.
Old 04-29-2005, 01:22 AM
ewheelin ewheelin is offline
I had the same oil leak problem on my 96 5.7, and I just found a threaded nipple for the oil filter off of an older 350 and did away with the cooler altogether. I'v had lots of 350s with out coolers, and had no heating problems. The electrical problem may be in the turn signal switch. My buddy just replaced his after encountering some problems with no brake lights, no high low beams and no 4 ways. It isn't a cheap piece, but I've seen them on ebay for under $100.00
