Go Back   Automotive Forums Car Chat > Dodge > General Discussion
Old 04-27-2005, 05:15 PM
grumpy4440 grumpy4440 is offline
Question 93 Shadow squeeking belt
Hey all, I got a 93 Dodge Shadow converteble with a 2.5L automatic 3 speed. The problem is the serpentine belt squeeks and I can't get it to stop. I have replaced the belt, checked the alternator bearings, the water pump does not leak. I know it's this belt cause, I have taken it off and the squeek stops (and I replaced the other belts too.). Does anybody have any ideas on how to quiet it up. I am at my wits end. I have tried all that I know. Any and all help will be greatly appreciated.
chris
Old 04-27-2005, 08:21 PM
Ryan066 Ryan066 is offline
is it tight?
I do remember seeing a belt lubrication somewhere.. maybe that would help...but hopfully it wouldnt slip off.
Old 04-27-2005, 09:02 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: 93 Shadow squeeking belt
There must be a way you can tighten it. Is it a real serpentine that just has a tensioner or is it a vee belt where you can tighten it from the alternator or a/c pump or somewhere?
My Mopars
Old 04-28-2005, 04:48 PM
Yeah it's tight. It does run around a tensioner, but like I said all is tight and running true (as far as I can tell).
Old 05-03-2005, 12:34 AM
yogi_123rd yogi_123rd is offline
Parts stores sell spray cans of "Belt Dressing". That's a substance that's a bit tacky and you spray it on the belt and the pulleys. Stops the belt from slipping.
Old 09-20-2005, 11:35 AM
SikEnCide's Avatar
SikEnCide SikEnCide is offline
Send a message via AIM to SikEnCide
hadthe same problem thought was my alternator beraing turnes out to be the belt... i buaght a replacemtn a cheap one and it still squeeked.. finally i spent the money and baught a little bit more expensive belt and no more squeeking. ... also one again make sure you belt it tight. or not over tightened
Old 09-21-2005, 05:58 PM
Thanks all for your responses. I fixed it, it was the rubber bushings in the upper mounting bracket. They were worn out and out of alignment. I replaced both of them and checked to make sure it was all in a straight line ( had to shim one of them ). All is good now. thanks again all.
