Go Back   Automotive Forums Car Chat > Toyota > Celica
Old 04-27-2005, 05:14 PM
blakscorpion21's Avatar
blakscorpion21 blakscorpion21 is offline
17 inch rims/speedometer
i put some 17s on my car and i was wondering if this would effect my speedo.?i ran more 0-60 runs and they were slower than b4. b4 i put them on i was running 9.8-10.2 in 0-60 and after the wheels were put on i ran a 11.1. can putting on bigger rims make it slower or is it just the speedo.?
Old 04-27-2005, 10:42 PM
tEaM_oMeGa tEaM_oMeGa is offline
Re: 17 inch rims/speedometer
they rims might be a problem....because the bigger the rims the longer it takes the wheel to rotate around.. but correct me if im wrong.
3SGTE...most powerful 4 cyclinder engine toyota has built.....260 hp..310Nm
It not a scoop, Its a VENT....Get it through your head,,,,,,
Old 04-28-2005, 12:29 AM
LaYzIeNoY LaYzIeNoY is offline
Send a message via AIM to LaYzIeNoY
ya its probably the speedo
i know that getting larger rims, will throw the speedo off depending on the size change, its just an adjustmnet that needs to be made, your not going slower, the guage is just reading wrong
Old 04-28-2005, 04:42 PM
91 Celica St 91 Celica St is offline
AF - Advisor
what size tires do you have on, if you have 45's or 40's it wont change ur speedo, but yes bigger rims/tires effects your launches, its kinda like the idea behind a lighter flywheel or underdrive crank pully, its harder to turn bigger heavy rims than it is to urn light 13's like ur steelies
Old 04-28-2005, 04:58 PM
i think theyr 45 that kinda sucks though i feel like i have to choose between looks and performance. maybe ill try to get a little bit smaller tires next time and that might help.
Old 04-29-2005, 10:08 AM
AF - Advisor
yea try and get at least 40's....get falken azenis those tires are sick
Old 05-01-2005, 08:11 AM
my new tires killed my low end power u think i could go 1 size smaller than 40
Old 05-02-2005, 11:35 AM
AF - Advisor
probably, look for a rim tire converter theres a few ones online that can see how close to stock that combo would be, and 45's with 17's should be the exact same size as mine, and you really shouldnt be noticing a loss in power, mabe you did something bad at the same time....
Old 05-02-2005, 04:17 PM
what could i have done? my uncle has 17s on his dodge avenger and his tires are a smaller size than mine.
