Old 04-27-2005, 02:04 PM
Vlad ink Vlad ink is offline
88 cherokee won't start (sometimes)
88 cherokee w/inline 6 won't start sometimes.
battery is good
alternator is working properly
but sometimes I will go to crank and nothing happens. When this happens The dash indicator lights don't work when ignition is turned
and the headlamps wont work it's like the whole electrical system is dead. No sound from starter solenoid. I get 12v at battery.Tried jumper from + battery to starter solenoid and it will sometimes click once after that nothing.Tried to start in nuetral no luck. Walk away for an hour get a bite to eat and it magically cranks usually good for 5-10 more starts and repeats this vicious cycle. Any help would be appreciated.
Old 04-27-2005, 06:51 PM
Dale Aeppli Dale Aeppli is offline
Re: 88 cherokee won't start (sometimes)
battery is good
Try cleaning battery terminals and the battery post, check and tighten the cables especally the battery ground cable.. Make sure where they are connected is clean. Check for loose connectors on cables. If cables are orginal they could have corrision inside causing voltage drop Dale
Old 04-27-2005, 09:19 PM
bulletpc bulletpc is offline
I have an 89 and I had that problem just today it was the connection at the starter. It is the small starter wire that delivers power to the starter and the interior or it is a bad ground at the battery.
Old 04-28-2005, 08:54 AM
Re: Re: 88 cherokee won't start (sometimes)
Thanks Dale I have already removed and cleaned all connections at starter solenoid and the battery posts and ground at engine block.
Any other suggestions?
Old 04-28-2005, 09:06 AM
Thanks I have cleaned that connection and the problem persists. It seems like a bad ground somewhere but I can't find it. Checked ground connection near fuse block and found another in back rear fender both are good. If the solenoid was bad would I loose juice at headlamps?
Could it be a bad ignition switch? I don't know if these are silly questions
but I thought I'd throw them out. Remember I am just a ham fisted pipe fitter not a mechanic. any ideas?
Old 04-30-2005, 10:32 AM
okay the hot wires that go from the battery to row of relays
there is big terminal hot wires most are green for about 3 inches one is blue for 3 inches or so they all have rubber boots on them (fuse links?)
then switch to red and most tie to harness that runs under radiator.
anyway if I move that group of wires around the jeep will regain power and crank 99% of the time.
Anyone have any ideas why? coincidence? Help?
Old 04-30-2005, 02:54 PM
Saudade's Avatar
Saudade Saudade is offline
Most likely a loose connection in there or a wire has broken inside the insulation. Keep working at it. You've almost got it.
Are you moving the harness near the relays or under the radiator?
Old 05-01-2005, 08:47 AM
Just near the relays. All have rubber boots are these boots just connections or are they fuse links?
