Old 04-27-2005, 01:59 PM
kallenbach_05 kallenbach_05 is offline
Black Smoke
i noticed black smoke coming from the exhaust and i was wondering if anyboday had any idea of what could be causing it. '97 SE 90K 2.4L.
Old 04-27-2005, 03:51 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Black Smoke
Black smoke would indicate that your car is burning oil. You may have bad O-rings, or even possibly a bad head gasket. You could also be running really rich. Any other symptoms?
Old 04-27-2005, 07:12 PM
Re: Black Smoke
nope, thats about it. it doesnt do it very much. i just started it noticing it today when i put the pedal to the floor from a takeoff. other than that it runs fine.
Old 04-27-2005, 10:13 PM
Hoags's Avatar
Hoags Hoags is offline
Re: Black Smoke
Make sure yoou keep an eye on the oil and coolant. If you have a bad head gasket you will have issues develop with the coolant and oil.
Old 04-27-2005, 10:30 PM
superfret78 superfret78 is offline
Oil being burned usually causes a bluish smoke...it sounds like you're running rich, which means you've got too much fuel getting into the combustion chambers. I'd check for leaky fuel injector(s) and/or fuel pressure regulator.
