Old 04-27-2005, 12:22 PM
OJDee's Avatar
OJDee OJDee is offline
Clearcoat confusion
Hi all,
I've been reading many posts about the use of clear coats, in particular Tamiya products, and I am a little confused about the exact products being used.
I have sprayed TS paints direct from the can but not with a clearcoat as yet. As I am aiming for the type of finish, particularly over decals, that I have seen on these forums, I'd like to know if I have the right end of the stick when it comes to clearcoats.
Tamiya make a clearcoat in a can (TS13) and also an acrylic clear in their little bottles (X22) Would it be possible to use the bottled clear through an airbrush and get the same results? I'm trying to avoid decanting the sprays if at all possible, so using the clear from the bottle straight over a TS colour would be great.
Also, let's say I wanted to spray a bottled colour, such as gun metal (X10). Could I lay the bottled clear over this and get a good finish?
I guess I'm just trying to gauge whether the only viable option for bodywork is the TS sprays (decanted or not) followed by the TS clear, or can most any tamiya acrylic paint be covered by either of their acrylic paints?
Also, if I was to decant and put a TS paint through my Iwata, do I need a more aggressive cleaner and is the paint generally nastier to work with than their bottled acrylics are?
Cheers
Oli
Old 04-27-2005, 10:06 PM
MidMazar's Avatar
MidMazar MidMazar is offline
Re: Clearcoat confusion
one thing i know that it is alright to use the clear over ts paints, not really sure on what the psi should be though.
In Progress
Old 04-27-2005, 11:36 PM
bvia's Avatar
bvia bvia is offline
TS-13 is NOT a friendly product. Improper application and usage can cause the lower paint surface to lift, decals to wrinkle, etc... It is a synthetic lacquer and a strong(hot) one. Practice and create a method/system for using it...I never bothered.
Acrylic clearcoats generally take a pretty long time to dry (Future not withstanding) and will never polish up like a lacquer or enamel due to it being a "softer" paint. When I clear-coat I use a 2-part automotive. Dries extremely quick and is rock solid.
hth,
Bill
Bill
"Why yes, that IS my bare, carbon fiber Enzo in Scale Motorsport's "How to Carbon Fiber Decaling video!"
Old 04-28-2005, 12:50 AM
druid_99's Avatar
druid_99 druid_99 is offline
As for me, I always apply all my paints using airbrush. The reason is when I'm using airbrush I can control the paint so that it won't bleed (I suck when using spray cans ), so, even when the clear comes in a spray can, I always transfer it into another bottle/container and use the airbrush to apply it.
As for your question on bottled clear over bottled colour, it can be applied but remember to apply a few layer of mist coats before the wet coats. FYI, I usually use automotive clear coats over Gunze colours..
What is understood need not be discussed
Old 04-28-2005, 05:16 AM
OJDee's Avatar
Thanks for your comments. Would I be right in taking from this that:
TS13 is a no no, because it's too aggressive to decals
X22 won't polish up to a nice auto finish, does this apply to future too?
Therefore automotive clear is the only way to go??
Some other peoples' experiences would be very helpful too.
Cheers
Oli
Old 04-28-2005, 05:24 AM
campenr.1's Avatar
campenr.1 campenr.1 is offline
Look here .
This guy uses Mr. Hobby Topcoat from Gunze Sagnyo over Tamiya TS spraypaint and it just looks stunning. Tamiya clear ruins the decals - so donīt use.
Current and past projects:
Old 04-28-2005, 05:56 AM
OJDee's Avatar
Originally Posted by campenr.1
Look here .
Is that both clears, the spray AND the bottled?
Oh yeah I forgot to mention that since I am in the UK, tamiya clears, future and automotive are my only options since I don't have a cheap reliable source of gunze products.
Oli
Old 04-28-2005, 06:31 AM
sjelic's Avatar
sjelic sjelic is offline
I can only add that I have tried number of automotive spray clear coats and this is the resoult.
Dupli color is good on dupli color paints but a killer for decals so no good, I have tried synthetic clear and it also doesn't like decals, tried few cheaper ones that are probably not common in UK but they are so cheap that you could buy few and test them, they are all acrylic and fast dryeing, they are kind to decals but some of them tend to yellow with time (over white) and some doesn't have the right shine.
Hese is the one I am most setisfied with.
And producer
and resoult
Sasa Jelic
SCALEMAKERS
Old 04-28-2005, 07:35 AM
OJDee's Avatar
Thanks Sasa,
It looks like I'm just going to have to sacrifice some kit bodies and decals to see what works. I'll get some automotive clears to try too. It does seem strange that Tamiya's products don't work well together, I'd have thought that their TS clear would be designed for use over their decals.
I was hoping that I'd be able to just spray the X22 clear through my airbrush over decals to get a showroom shine but things are never as simple as they should be I guess.
Perhaps future will do the trick and give me a shine that I want.
Oli
Old 04-29-2005, 08:47 AM
csl csl is offline
I've also found that the Tamiya clear spray can thin the paint over some sharp edges. The clear from the bottles works well, but as mentioned earlier, it is soft and takes time to cure. I'm not always looking for super high gloss, so the effect works fine for me. But I need to experiment with 2-part automotive clears. A lot of builders I know really seem to like them.
Old 04-29-2005, 12:53 PM
ClearHooter ClearHooter is offline
This is sort of off topic... But not. I don't use acrylic. I can't get the shine out of it. This wouldn't normaly come up, and especially not with acrylic, but I ran across this in modifying a MB Mustang Concept into a 2005 Mustang. Usually glass work is no issue. But the way the MBC is constructed the roof and tinted glazing are one in the same. The stuff they use to make it is soft and suseptible to anything. Even rubber cement. I use that for masking a lot of things. Had to repolish the glass after using rubber cement to mask it. Then I sprayed Krylon Triple Coat Glaze over the whole car after painting it. Anywhere the plastic wasn't protected by paint, it krazed. In desperation I cut two pieces of clear shipping tape to rough size and placed it over the krazing. It sealed the krazing to where you can see through the glass! Just a word of warning on "Clearcoat" and a, how to undo.
Old 04-29-2005, 03:06 PM
MPWR's Avatar
MPWR MPWR is offline
Image Hosting Exceeded
You most certainly can use X22 out of the bottle over Tamiya acrylics (or over ANYTHING else), and polish it out to a good shine.
This finish is entirely Tamiya acrylics- a mix of blue, purple, and gun metal, overcoated with acrylic X22 and polished. I found that the X22 dried plenty quickly, I only waited 48 hours after applying the last coat before polishing. It does take a bit of work and patience, but every body you paint and polish out will, and I found using the X22 to be easier to work with than hotter clearcoats, and a whole lot safer. I did the polishing with a Squadron polishing stick, and rubbed it out with Tamiya compound. This was the easiest body I've ever painted.
I've tried using Future in this way also, but it's definately inferior. I will both haze and crack if applied too thick.
Give it a try!
PHOTOBUCKET SUCKS
Old 04-29-2005, 03:54 PM
mickbench's Avatar
mickbench mickbench is offline
This has been a useful thread. I have problems using TS-13 clear, but looking at what MPWR managed to do with X22, I will be giving this a go next time. Thanks all..
Old 04-29-2005, 06:06 PM
OJDee's Avatar
Yes completely agree, thanks MPWR for proving that it can be done. If I can get that sort of finish reliably I'll be very happy since it's both easy to obtain and put through an airbrush.
Cheers
Oli
Old 04-30-2005, 06:09 PM
Nobbys Nuts Nobbys Nuts is offline
Which x22 are we talking about here as Tamiya does x22 as a enamel as well as Acrylic and I have used that (the Enamel one) over their spray paints with no probs but I prefer to use Testors Modelmasters Hi Gloss Clear.
