Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-27-2005, 09:32 AM
phil73 phil73 is offline
suggested preventive work on rodeo 2001 v6 3.2
Hello,
My Canadian rodeo 2001 is getting out of warranty ( 55 k miles) and I 'm about to take care of it myself.
I haul a trailer tent (2000 pounds) 2k miles per summer, usually on mountain roads, we have pretty cold winter up to -30F (4-5 months using 4x4 praticly all the time) and I usually do 15k miles per year
What would be the preventive work you would suggest me to do on it ?
thanks
Philippe
Phil 73,
Happy owner of a Isuzu rodeo 2001
Old 04-27-2005, 10:55 AM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: suggested preventive work on rodeo 2001 v6 3.2
1. I would flush the transmission yearly (before the towing season). Due to the cold climate I would not recommend a tranny cooler (and you are only towing 2000lbs).
2. Use synthetic oil (mobile 1 or the likes) year around due to the cold climate (changing at 3-4K).
3. I personally add a half can of sea foam before I change my oil (add and then take it for a 20 minute drive and then change the oil ASAP, while it is good and hot).
4. Pull your PVC valve at each oil change AND before you tow and give it a couple sprays of carb cleaner. I have permitly removed the plastic (V6) engine cover so i have easy access to the PCV. I also, spray my PCV out about every 1k.
5. Clean the EGR and EGR port yearly.
6. After that it is up to you, Plugs every 50K, fuel filter 30K, S-belt 35K, Rear/front diffy oil 30k, Bleed brakes (?) 50k, Power steering flush (30K; I do this yearly), H20 30k (I do this yearly), Air filter (yearly) .......
Read the FAQ's for a bunch of tips and things to look out for.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
