How do I get Fast?!
I have a 1999 Firebird with the V6 I want to make it faster but I don't knowwhere to start. Can anyone help me?
Re: How do I get Fast?!
if I were you, using a v6...I'd just do one of the following. 1. Nitrous(wet kit) 2. STS Turbo kit. Either of these are your best bet. The turbo will always be there, the nitrous only when you hit the button granted you have a fairly filled bottle. Any other chose, In My Honest Opinon, is a waste of time and $$$ for the power/$$$ ratio.
DarkblueTA GT70, FMIC, Alky-water injection, Hooker Cat back, 208/230 .549/.579 121LSA Cam, forged diamond pistons/eagle rods, LS6 block, Lakewood LCAs, BMR STB/PHRB/Sway Bars, poly torque arm bushing, Spec Stage 4i clutch, B&M Ripper Shifter, SLP Subframes, 60# injectors, KYB AGX shocks/struts, Moser 12 bolt(373 gears, 33 spline axles, posi, ta girdle/etc/etc/etc) and HPTuner kit 2007 Nissan Titan Daily Driver. 2* advance
Re: Re: How do I get Fast?!
My suggestions are bolt on mods, such as: Intake (Preferably K&N) Headers Hi-Flow Cat Cat-Back exhaust (suggest Magnaflow) Those are just mods to help get your engine breathing better. That should give you enough satisfactory amount of power gains to get you started off.
- Jason 1995 Pontiac Firebird ![]() ![]() User Guidelines | VB Codes Explained | AF Merchandise "Each of us, is in the scheme of things, insignificant. But millions of insignificant people, doing a tiny bit, can add up to be a very significant force." |
Re: Re: Re: How do I get Fast?!
he had a dry kit... Never run a dry kit. also we don't know how much timing he had taken out of his enigne. nitrous makes the charge burn quicker so you have to remove timing. Hell if you have enough of the shit, you don't have to have any advance at all. It will burn fast enough to have 0 degrees of spark advance
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
Gears are a huge bang for the buck mod and combined with Headers , Cat back , CAI and some tuning can make a world of difference but if your looking for a major increase in performance , your looking at forced induction or NOS.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
Re: Re: Re: Re: How do I get Fast?!
Agreed. That's why if you re-read my post, its a wet kit. Just make sure when it is hooked up that the jets sit between the Mass-Air Flow Sensor and Throttle Body. Also if you do this, run colder set of plugs.
hey boss hogg check out the guys at www.firebirdv6.com look in there mods section and join there mesage board
but on another note stay away from the dry shot it is easyer but a wet setup though it can still cause problems you dont have the worries of goin lean and breakiin stuff
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit 93 accord 4 door auto stock |
