Old 04-26-2005, 10:21 PM
jacobnewfield jacobnewfield is offline
Send a message via MSN to jacobnewfield
Door Lock Replacement
I purchased a 91 Honda Civic LX with 187,000 miles on it. The driver side door lock is very ruff when I turn the key to unlock or lock the door.
Is there a way to replace the door lock without replacing the whole door?
Old 04-27-2005, 10:01 AM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
Re: Door Lock Replacement
take your door panel off, roll the window up, and look at the backside of the door handle. theres a rod that attaches to the lock, and a small c-clip that holds the lock cylinder in. if you take both of those off the cylinder will come out.
maybe try lubricating the cylinder first with some spray, because you will need a locksmith to change the tumblers inside the new cylinder if you decide to put a new one in.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 04-27-2005, 12:42 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
remove the locks permanently. Replace your door handles with rear-door handles from a sedan, remove the lock rods... get a keyless entry alarm.
Old 04-27-2005, 09:04 PM
livinincalifornia livinincalifornia is offline
Send a message via AIM to livinincalifornia
someone drilled and popped the lock on my car on friday not sure if I should try keyless or just try to get another lock made with the same key.
Old 05-02-2005, 12:49 PM
I used W-D40 and uvula, the lock wasn't ruff anymore. Good thing too, sounds like replacing the lock is a more complex job than I thought.
Thanks...
Old 05-02-2005, 12:59 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Re: Door Lock Replacement
Thanks...
glad to hear it... but for future reference, a "uvula" is the thing that hangs from the back of your mouth... I think you meant "voila".... LOL!
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 05-02-2005, 02:44 PM
hatchitup hatchitup is offline
hahahahaha
Old 05-02-2005, 07:00 PM
Re: Re: Re: Door Lock Replacement
This is me embarrased...
I will have to remeber that to save face in the futre.
