Old 04-26-2005, 08:53 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
OBD1 MPFI Questions
I'm wanting to know if I'm going to have any problems using injectors/manifold sensors/throttle body off a 92 with a pm6 ecu. I know the injectors dont use a resistor box but other than that is anything differnt?
edit:
Oh yeah and the dizzy also.
Old 04-27-2005, 05:47 PM
Forunn Daberator
Re: OBD1 MPFI Questions
Bump
Old 04-28-2005, 12:07 AM
ef four door's Avatar
ef four door ef four door is offline
Other than the injectors, all the plugs on the IM are the same from obd0 to obd1. You might have an extra coolant line however. Dizzy wont work for sure, unless u run an obd1 ecu.
1989 civic lx four door, MPFI SOHC ZC powered, SOLD
1988 civic dx four door, D15B VTEC...permanently converted to obd1
