Old 04-26-2005, 06:16 PM
poordudewhowantcar poordudewhowantcar is offline
Send a message via ICQ to poordudewhowantcar Send a message via AIM to poordudewhowantcar Send a message via Yahoo to poordudewhowantcar
B18B/A Install Questions
what type of cable tranny could i use on the b18 the only one that i know of is the (b16 cable) . also what type of shift linkage could i use ? The mounts could i use my stock 1's i noticed that i have a crack in the Left motor mount could i just put a polyurathane insert on all the mounts for better stablization ? Last the wiring harness the one that i have now is for a d15 but i can get a hook up on the b18 wiring harness should i just buy the b18 harness an install it ?
Old 04-26-2005, 06:46 PM
travagliante's Avatar
travagliante travagliante is offline
Re: B18B/A Install Questions
First off id do some research before you try to jump into a swap like this. Any FWD b-series tranny, cable type, will work! 2nd gen teg, b16a ones jdm teg Xsi ones. etc etc.
Shiftlinkage: Use stock shift rod and shortened 90-93 teg extension rod. Or buy aftermarket ones(hasport, hcp, ebay, whatever!)
Convert to mpfi, and you stock harness will plug right up if its a obd0 motor!(b18a) Use a 90-91 Teg PR4 ecu.
Use 90-93 teg axles, you cannot use stock mounts, need aftermarket ones.
