Go Back   Automotive Forums Car Chat > Honda > Civic | CRX > '96-'00 Civic
Old 04-26-2005, 06:58 PM
2000hondacivic4dr 2000hondacivic4dr is offline
Send a message via AIM to 2000hondacivic4dr
Radio Removal
Can someone send me a link to show me how to remove a stock head unit from a 2000 civic? also howw to install an afteramrket one. thanks
Old 04-26-2005, 09:05 PM
Rangers_86 Rangers_86 is offline
Send a message via AIM to Rangers_86
00 Civic Radio Removal
2004 Ep3
Old 04-26-2005, 10:43 PM
siege911's Avatar
siege911 siege911 is offline
Send a message via AIM to siege911
Re: Radio Removal
All I can say is to get a manual... I have a Helms manual for the 96-00 Civic, and it works wonders... tells me exactly where every bolt and screw is. I used it to take out the head unit and put it back in, and I would recommend it. Definitely worth the money.
www.civicland.com
www.turbod16.com
Originally Posted by Ace$nyper
The Popes really a vampire in a pyramid scheme to bring Attila the hun back from the dead.
You all are fucktards and would bow to the ls1 and my 54 foot long ninja sword.
Old 06-02-2005, 02:30 PM
titantn24 titantn24 is offline
Go to www.hondaunlockcodes.homestead.com It will cost 3 or 4 bucks, but it saved me a lot of time and headache.
Old 06-04-2005, 12:41 PM
_93civchatch_ _93civchatch_ is offline
if you do not know how to put in an aftermarket radio then i wouldnt try, you'll probably mess it up. its not that its hard, its actually very easy, but alot of people dont put the cage in right and then it moves around and crap. and as for taking the old one out. you have to take off your complete underdash on driver side, take off your glove box door and then take out the center underdash. then you should have 2 8mm bolts to take out and the radio will slide right out.
with the new one, youll need a wiring harness, just match all the same colored wires up, ex: purple with purple, black with black, and look for stripes too cause those need matched up with the other stipped ones... like orange with white stripe... you should be able to figure it out though... why dont you just got to best buy, buy a radio over 100 dollars and they will install it free... youll just need to buy 30 dollars in parts..
