Hey Everyone,
I have a 98 Blazer. Everything works, except the front wiper MISTER. The blades move but I don't hear the pump going. Can someone give me the diagnosis possibilities. THANKS! |
Do you hear the motor running when you press the "washer button" on the turn signal stalk? If so, check for obstructions in the lines, see if the pump picked up garbage from inside the reservoir, and so on. If you don't hear the motor run, then pop the wire off the washer fluid pump, connect a test light/volt meter to the power wire for the pump, have someone hit the switch and see if you have power to it. If you do, then the pumps fried. If not, check fuses, etc.
Check for obstructions in the lines, see if the pump picked up garbage from inside the reservoir, and so on. If you don't hear the motor run, then pop the wire off the washer fluid pump, connect a test light/volt meter to the power wire for the pump, have someone hit the switch and see if you have power to it. If you do, then the pumps fried. If not, check fuses, etc.
Sorry for the double post - crappy Internet connection today. Wanted to revise my first one since I noticed that he said he couldn't hear the pump running....
Re: Front Windshield Washer
The mist feature does not engage the washer fluid.
It is a setting for one single wipe to remove and mist on the windsheild.
1995 Factory Blazer Service Manual for sale, PM if interested. |
Re: Re: Front Windshield Washer
Re: Re: Re: Front Windshield Washer
I assumed that he meant the washer function. That's what I get for assuming.
