Old 04-26-2005, 02:44 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Exhaust Question
The exhaust Im going to be putting in has no o2 sensor holes I believe. The downpipe definately doesnt but Im not sure about the catback because I dont have it yet. Can anything serious happen if I dont have those sensors in my exhaust? What would some fixes be besides wrapping them in aluminum foil?
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 04-26-2005, 03:00 PM
silver98GST silver98GST is offline
Re: Exhaust Question
Does your downpipe eliminate the cat? Well, another way I read to trick the sensor is by putting a bolt in the downpipes o2 sensor hole (if it has one) then just clamp the sensor to the side of the exhaust.
There's a discussion similar to this about 02 sensors:http://www.automotiveforums.com/vbul...d.php?t=196149
You should definitely read that forum especially since Kevin, the expert DSMer, is sharing his knowledge.
1998 Eclipse GST AT
Mods: FP intake pipe, K&N filter, MBC, Glowshift pillar pod w/ tinted gauges (boost, A/F, oil temp gauges), Blitz DTT DC2 turbo timer, Greddy Type S BOV, Apexi N1 exhaust, Megan downpipe, Dejontool blow thru UICP, GM MAFT, Denso 660cc injectors, ARP headstuds, 3000gt sl big brake upgrade, Eprom ecu, DSMlink V2, etc.
Come visit my cardomain page!
Old 04-26-2005, 04:25 PM
yea Ill check into that, also my downpipe does eliminate the cat, sorry, forgot to mention that
95 Eclipse GS-T
Currently:
Soon lol
Old 04-26-2005, 05:10 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
does the downpipe also eliminate the o2 housing? It's not in the downpipe. search around, i know there are several ways to eliminate the ECU's need for an o2 sensor at the cat.
Old 04-26-2005, 05:21 PM
Yes it doesnt have an o2 housing, sorry I should have made myself more clear.
95 Eclipse GS-T
Currently:
Soon lol
Old 04-26-2005, 11:48 PM
JoeWagon's Avatar
Banned
I find it hard to believe. All DSMs need the front o2 sensor to run, so why would an o2 elim downpipe not have an o2 sensor bung? Are you absolutely sure it doesn't have a hole for it? Is it a DSM brand name piece? If not, you will need to do this custom or get one that has it.
Old 04-27-2005, 11:57 AM
its from megan racing, im assuming the bung is basically a hole in the downpipe towards the top? Ill try to post a pic of it or a link to it when i get a chance to look for it
95 Eclipse GS-T
Currently:
Soon lol
Old 04-27-2005, 11:59 AM
http://cgi.ebay.com/ebaymotors/ws/eB...category=33630
heres the link
95 Eclipse GS-T
Currently:
Soon lol
Old 04-27-2005, 03:04 PM
Gsx_hooptie Gsx_hooptie is offline
Re: Re: Exhaust Question
That doesn't look like it removes the o2 housing. Your front o2 sensor stays where it is and does its job fine, in the (stock) o2 housing. The pipe narrows to accomodate the welds to the flex section, though.
Keep in mind that front o2 and rear o2 sensors are separate and very different.
The classiest solution would be to remove the rear o2 sensor and close the circut with a resistor. See vfaq here: http://vfaq.com/mods/O2bypass.html Aluminum foil also works.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 04-27-2005, 04:04 PM
I think I got mixed up, I was thinking about this earlier....Is the first o2 sensor in the o2 housing?? Because if so I have no problem, it would be just the rear o2 sensor I would be worried about, thanks for the help guys. Im trying to learn as much about cars(dsms too) so I can do a rebuild once my car doesnt run anymore.
95 Eclipse GS-T
Currently:
Soon lol
