Old 04-26-2005, 01:56 PM
mus5.0tang mus5.0tang is offline
Send a message via AIM to mus5.0tang
check engine light question
i just put an o/r x pipe on my 94 mustang. i also plugged the smog pump. on heavy accelerations the check engine light pops on.. then it goes back out. anybody know what this could indicate??
Old 04-26-2005, 04:07 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: check engine light question
The O2 sensors need MIL eliminators........
My ride at my site Silverstangs.
Old 04-26-2005, 06:06 PM
it only has the o2 sensors that are before the cats to begin with neways. not the after cat o2s
Old 05-01-2005, 10:34 PM
99DenaliMan 99DenaliMan is offline
I don't know what year 5.0 you have. However, I currently have mine torn apart. It seems there are two passages (one on each head) that mixes (pumps) clean air with your exhaust on the stroke. This air seems (I assume) to lean out the a/f mixture leaving your engine, and the cats are suppossed to do the rest. Seeing as how you plugged the pump, the reading is more than likely rich. (even before the cats.) This is just a guess, but I guess your burning a lot more fuel than usual? I am no expert on emissions, so someone correct me if I'm wrong. I am getting ready to do the same. I have posted a thread--theoratically this should work? but have yet to receive a response. Hope this helps.
Old 05-06-2005, 01:55 PM
TwEeKeDStang TwEeKeDStang is offline
Send a message via AIM to TwEeKeDStang
Not to make it sound like I think you're an idiot or that I AM an idiot (by all means I may be) but did you do anything to the computer? I know these 90s stangs dont deal well with mods (even just exhousts) and can cause the engine mod not to work properly. I know I had to do that when I added new headers. Check that out.
Also, I also had the engine light problem (before the computer) and it could also be the O2 sensor, or could just be a slipped belt. Those are two previous reasons for my engine light to go off. Also, speeding at 115 and swerving from a pot hole made mine go off... as did the old joke, "Check engine?... Engine, check." And closing the hood... yellow lights piss me off...
TwEeKeY Says:
"Meh 'stang be ownin' yer ricer..."
IRELAND FER EFFIN' EVER
