Old 04-26-2005, 10:27 AM
rtyska rtyska is offline
Quick Question About Drilling Through Firewall
Hey guys,
Installing an amp/head unit/sub into a friend's car and I was hoping you could give me a little guidance as to where the best place would be to drill throught the firewall, on the passenger side.
I also need to know if the gas tank is right under the trunk since I want to secure the box in place with some l brackets . . . and I certaily don't want to drill into something like the gas tank.
Thanks!
da pig
Old 04-26-2005, 03:35 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Quick Question About Drilling Through Firewall
Rtyska, if you look on the firewall, there is an eyelet somewhere on the driver's side. It goes through the firewall - lots of wires are run through there, and you should be able to run your wire through there.
And yes, the gas tank is underneath the trunk. I wouldn't reccomend drilling through it. If you were to design the bracket so that it could be attached in the wheel well area though, that would work.
Old 05-14-2005, 03:19 PM
prsoto21 prsoto21 is offline
I found an opening below the glovebox which worked well for 4 gauge wire. Just be sure to silicone around the wire.
Old 05-17-2005, 10:38 PM
slicshake slicshake is offline
Send a message via AIM to slicshake
hey, i'm looking to install an amp of my own and i'm looking for a spot to drill through the firewall as well.. Could you please give a discreption of aproxemantly where you drilled, a picture would be even beter. Like your its 4 gauge awg. thanks alot.
