Old 04-26-2005, 10:11 AM
nachoman nachoman is offline
Unhappy 01' starting problems!!
Hey guys and gals. Here's the problem: About a week ago, my cavalier (2001 2.2 A/T, 62k mi) started rougher than normal- as if the power was drained. Then the next time it was started, it was worse. I then started it 3 or 4 times and on the fourth time, it wouldn't start at all- Just rapid clicking from the starter. I took the battery in to autozone for the free test and charge. They charged it up, and said it was still a good battery. So I hooked it back up and it fired right up. Two days ago, it did the same thing in my garage. (I started it up about 4 times and it finally wouldn't start...just rapid clicks.) So I had the alternator tested. IT's fine. I cleaned the battery terminals, connections are good. Still- just clicks.... Then yesterday- the car started on the first try with little hesitation. WTF?!?!
I have no idea what it is. It doesn't sound like a fuel issue. The battery and alternator are good. Might it be a starter/solenoid? I don't want to replace anything until I know for sure... I appreciate any advice!
Old 04-26-2005, 10:21 AM
S_chevy S_chevy is offline
Re: 01' starting problems!!
sounds like the starter is the problem to me.
"War is cruelty. There's no use trying to reform it, the crueler it is the
sooner it will be over."
-William T. Sherman
Old 04-27-2005, 06:38 PM
Re: Re: 01' starting problems!!
I'm thinking it's the starter solenoid. Would that be a separate issue or do I have to replace the entire starter as well??
