Old 04-26-2005, 09:59 AM
riff22 riff22 is offline
Unhappy 550cc injector problem
installed my 550cc injectors and the car ran like ran like shit, amost like the spark plug wires where mixed up but they were right. i dont have my pump in yet cuz im waiting on my regualtor, would that be the problem? the stock pump cant keep enough pressure because the holes in the injectors are so big? i took them out and put the old ones back in and it ran fine. i also played around with the safc too, i stated on low-thr and started at the base line of -18% and i coudnt even get it to idle right.
-1995 Eagle Talon TSI AWD
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-walbro 255 fuel pump
-550cc injectors
-pocketlogger
-2.5 full exhaust (no cat)
-30 psi bov
Old 04-27-2005, 02:45 AM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: 550cc injector problem
Set the Lo-throttle points to -10% across the RPM range. Make sure you have 4 cyl selected under "car select" and the arrow points up for thottle. Then make sure you select "Karmen" freqency for the air flow in the settings. Once you do all that and if it still does nothing then recheck your wiring and make sure its hooked up right!
Old 04-27-2005, 07:09 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: 550cc injector problem
Just out of curiousity, why would you suggest -10%? I was under the assumption that it should be -18%.
(450/550) - 1 = -18%
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
