only getting 11mpg out of my 94 s-10 4.3tbi need help
Hello Everybody. I need you help the truck is breaking me up. The truck seems to run real good someday and other days it has a slight hesitation but it alway eats the gas. I cannot smell gas like it is running to rich it just uses alot of gas. The truck is real powerful 4.3l tbi. Any ideas. Mark
Re: only getting 11mpg out of my 94 s-10 4.3tbi need help
tune up and check timming.
Re: Re: only getting 11mpg out of my 94 s-10 4.3tbi need help
1995 Factory Blazer Service Manual for sale, PM if interested. |
Also check your injectors. They should be spraying a fine cone... If they are dribbling at all they should be replaced. As said above, do a tune up. Since you're getting such bad miledge do the following
Cap rotor plugs wires 02 sensor(s) pcv valve air filter (good time for a k&n) Fuel filter LOF (Lube, oil, filter) Check tire pressure Grease all chassi points If you can, differential and transmission fluid change... Take care of your car and your car will take care of you!
![]() ![]() 95 s10 Blazer, EGR Mod, ZQ8 Steering box mod, 99 Center console shifter mod and more... See everything at www.pghconsulting.net/teal |
Here is a list of things already done
plugs cap and rotor k& n air filter wires injectors oil changed last weekend o2 sensors |
also forgot to memtion a new tps sensor.
Dont forget to check your timing and reset the ecm after any electrical/sensor related changes.
Trailblazer 2005. 2WD LS Brand new, No Mods Yet! |
Remove the timing wire from the PCM and set the timing to zero with a timing gun.
Then reattach the timing wire, reset the ecm by pulling the negative cable for ten minutes and see if it helps.
you wont get better than 16 probly even after everythin is placed. Those TBI are junk. I have one in my fullsize.
how many miles are on it? Then we can decide if you can get 19... or 15... or less...lol |
junk!??? BULLS**T!! cant call it junk because of your gas mileage. having a truck that is not being taken care OF will turn to junk. how many miles are on your truck, drag it? how many times have you put off doing preventive maintainance? thats how vehicles turn to junk.
My truck has 150000 miles on it and I have not checked the timing yet I will do it this weekend. I work with the guy that owned it before me and he said that it was getting 16 to 18mpg city and one day it started to run a little rough and the gas mileage dropped. I have since bought it from him and put in in the shop and they put a new tps sensor on it and it ran a lot better but the gas mileage has not went up. Mark
