Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 04-26-2005, 09:15 AM
sharkdude sharkdude is offline
O2 Sensor
Check engine light came on, so I took the truck by Autozone. They said I have 2 O2 sensors bad and the knock Sensor. Now way im chaning the Knock sensor because I know where it is located.
Does anyone know where the O2 sensors are loacated, or is there an online diagram showing where they are.
Any help greatly Appreciated........
Old 04-26-2005, 10:56 AM
OffroadX OffroadX is offline
Send a message via AIM to OffroadX
Re: O2 Sensor
The O2 sensors in the exhaust just before and just after the primary catalytic converters. Which two of the 4 are showing bad?
And a bad 02 sensor reading can be caused by any number of things including vacuum leaks, bad injectors, or a poor ground.
You need the specific codes to be any more specific.
Old 04-30-2005, 11:10 PM
jacks336's Avatar
jacks336 jacks336 is offline
Exact same thing happed to me last october... I broke down and went to the dealership and had them take a look at it. They came back with a tech bulletin that said that the wireing harness might not be grounded correctly. I bought a new wireing harness and that did the trick i have put about 23,000 miles since that was done and no check engine light
