Old 04-26-2005, 09:03 AM
chuck16's Avatar
chuck16 chuck16 is offline
Question Temperature Control...
Hey Guys,
I've done some searching and haven't found an exact answer so I just thought that I would pose the question and see what results came out.
Is your Temperature very Variable? IE: Do you have a good mix of Cold/Warm/Hot Air.
It would seem on my 99' that only the last little bit on the cold side shuts the heat off. The heat is HOT HOT HOT and I have pretty good variation with the A/C on. However, in just regular operation it would seem like just the last little bit of the Cool indicator((Knob turned almost all the way counterclockwise)) allows a decent mix of warm and cold air.
This is with fresh air coming in and not in recirc incase anybody is wondering.
I am wondering if I should change the "Heater Accuator"? It would seem that is what a lot of the other posts are pointing to but, I just wanted to make sure I was on the right track before I start throwing money at it.
Thoughts???
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 04-26-2005, 02:47 PM
TXAGG05 TXAGG05 is offline
Not sure if this is what you're looking for, but in my truck it is usually hot if not turned all the way to cold. It doesn't get much below freezing here during the winter and I never turn my heat past halfway because it gets too hot. Even when I go to Taos, NM in the winter I usually can't leave the temp knob past halfway once the cab warms up.
Without the compressor turned on my temp usually depends on the outside temperature(cold vent when I have it set on cold and it's cold outside, but warmer if it's warmer outside). I just figure this is normal, but you might be talking about something else.
Jeb
2002 Chevy Z71 Ext Cab, Black
2004 Blue Wave 180-V, 90hp Yamaha Outboard
Pre 1960 Duck Boat, 9hp Mercury Outboard
2002 Argo Conquest w/ tracks
Also driving, but not at my house:
2001 Pierce Saber
1989 Pierce Dash
(See Pics in my gallery)
Old 04-26-2005, 02:50 PM
chuck16's Avatar
Re: Temperature Control...
Sounds the same as me but, I'd be interested to see if anybody has anything else to add. Thanks Jeb
Evan
2008 GMC ACADIA
I AM Canadian!!
