Old 04-26-2005, 07:38 AM
riff22 riff22 is offline
help ASAP!! lean or rich?
k i took my car for a hard drive and hear latly the digital A/F gauge i have has been reading 1.01-1.03 at WOT. which is rich, but after the run i poped the hood and the exhaust manifold and 02 housing where glowing red!! which means lean right, the tem gauge in the car is in the middle all the time but i noticed the top radiator hose getting melted. after a hard run you can hear the radiator fluid boiling, but my pocket logger says 199 deg. anybody have the same problem or any in put?
thanks
tyler
-1995 Eagle Talon TSI AWD
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-walbro 255 fuel pump
-550cc injectors
-pocketlogger
-2.5 full exhaust (no cat)
-30 psi bov
Old 04-26-2005, 08:04 AM
Re: help ASAP!! lean or rich?
i dont know if it has been doing this or not, this is the first time i saw it cuz it was dark out, if it was light out you wouldnt see it glow
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-26-2005, 09:00 AM
kjewer1 kjewer1 is offline
AF - Advisor
Its normal to see the manifold glow at night after some hard running when perfectly tuned. Being excessively rich can also make it worse since the excess fuel is still burning in the manifold. I dont trust narrow band O2 sensors as far as I can throw them, but being over 1 volt almost always means that you are pig rig. Might be worth looking into.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-26-2005, 09:28 AM
well it was on stock boost, 10 psi everything in my sig is not installed yet, the only thing i have on its safc and everything is set to 0. so i put my controller on and turned it to 15psi to lean it out a bit but at WOT again 1.01-1.03? i dont get it??
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-26-2005, 09:30 AM
after i saw the manifold glowing red, i dont think i want to install my new turbo
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-27-2005, 11:09 AM
AF - Advisor
You must have missed the part where I said a glowing manifold at night after hard driving is normal...
Over 1 volt is probably rich. Raising boost does NOT lean out AFR unless you run out of pump or injector.
Kevin Jewer
Old 04-27-2005, 12:21 PM
so when i get my reg., pump and injectors on should i turn the reg down or run it at 43
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-27-2005, 01:27 PM
is there a reason why im running rich stock? i get horrible gas milage 170 miles to a full tank!!
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-28-2005, 12:31 AM
AF - Advisor
Run at stock fuel pressure, its what the ECU is assuming it will be. Poor fuel economy is usually a bad O2 sensor, wether or not it throws a DTC.
Kevin Jewer
Old 04-28-2005, 07:38 AM
could the o2 sensor be bad and still give a reading on a digital gauge? i know that the sensor has been covered in oil because of the turbo seals on the old turbo, cant be good. i bought a new sensor from autozone bosch and it was too short and the plug was diffrent, i dont have the box so they wont take it back. they said thats all they have in there computer for it. i guess im going to have to buy a new and ask for on for an eclipse
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-28-2005, 08:16 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Buy an OEM sensor, it's plug & play.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 04-28-2005, 08:40 AM
AF - Advisor
I dont bother with autoparts stores for this reason. Better to buy O2 sensors at the dealer. Same goes for most other sensors and parts that are relatively important.
Kevin Jewer
