Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 04-25-2005, 10:28 PM
JTBarrett JTBarrett is offline
Several problems with '99, please help!!
First off, I've been trolling the forum and have seen some other topics that are similar, but no clear answers. So, I thought I'd start with a fresh post.
I'm having several problems with my '99 ES. I've got just over 140k freeway miles, so I guess it's time. I'll just list them in order:
1 - The worst problem is that it's stalling. It seems to usually be when I stop at a light or the rpm drops quickly. It starts right back up.
2 - My fuel guage and light is off about a 1/4 tank. It doesn't go up all the way and the light comes on way early.
3 - Oil light comes on when I'm on a slope going upwards. The oil is definitely full. I saw another post mentioning the timing belt. JFYI, I had the timing belt changed within the last 6 months. I DO NOT recall the oil light issue before the timing belt was changed.
4 - I get a very nasty pinging noise that sounds like it's coming from under the injector cover. It speeds up when I accelerate and is most noticable when idling. I've seen references that this may be the lifters, but not sure.
If anyone has a good idea of what these problems may be as well as how to fix them, please let me know
Thanks!
Old 04-28-2005, 08:41 AM
AdamOhio AdamOhio is offline
Regarding your stalling:
If you havent replaced your PCV valve in a while, try that. If that doesnt fix it, your problem is most likely your EGR valve. You would want a new PCV valve upon an EGR change, anyways, so try that first
