Old 04-25-2005, 10:46 PM
rtt1969 rtt1969 is offline
The 3 holes on the digital EGR valve
On my 1995 firebird 3.4 eng. I have a digital egr valve.
It has 3 holes on the underside. The trouble code says #1 solenoid failure.
I don't know which of the 3 holes is #1
There is a small hole, a little bit bigger hole and a bigger hole.
Does anyone know if the smallest hole is #1
or would the bigger hole be #1
Old 04-26-2005, 05:46 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: The 3 holes on the digital EGR valve
I would guess that the biggest hole would be solenoid #1. - Are you just going to clean it with carb cleaner, or what?
Old 04-27-2005, 12:21 AM
The check engine light only goes on if I am on the freeway over 55 mph and then slow down. So at 55 mph no light, when slowing down to 54 the light comes on.
Since I think NOx is higher at freeway speed, it makes sense that the big hole would open, and if it failed and showed #1, I guess #1 would be the big hole.
It's just that I am failing the smog check at 25 mph, but the light doesn't come on at that speed, only at 54 mph if I slow down to 54 mph.
I'm trying to figure out what hole opens at 25 mph.
The EGR works, I tested it, the connector has a good connection, I checked for voltage and ground. So I can't figure out why I would get a solenoid failure, if voltage and ground are going to the solenoids and the EGR valve is new, no carbon blocking the holes from opening.
Unless when the #1 is supposed to open, a sensor is shutting off the ground to that solenoid, but what sensor would tell the EGR to turn on and off. Both Oxygen sensors are new.
Old 04-29-2005, 09:00 PM
jason-1995fbody's Avatar
jason-1995fbody jason-1995fbody is offline
is it a new egr or one you cleaned
1989 camaro iroc 350 bored .060 over aluminum intake q-jet unknown big cam 194/150 valves ported and polished automatic /shift kit
93 accord 4 door auto stock
Old 04-30-2005, 09:30 PM
I first had this trouble with an old EGR a day after I bought the car, but the dealer did the smog check and I was good for 2 years, so it was no big deal and it was under the old smog rules, otherwise it would have failed for the dealer.
I thought it was a bad EGR valve when it said code 75 so I bought a new EGR valve for $200.00 and still had the same problem, code 75.
Now it's time for a smog check under the new california rules and it failed because of that code 75. So I tried everything I could think of to make it pass, but I wound up taking it to a mechanic and it
Finally passed. They said the EGR ports were clogged. I don't know how they could be clogged, since I tested the EGR and all 3 solenoids opened. But they cleaned it out and it passed the smog check. Cost me $340.00 to have that done, plus the smog check.
Here's what my #'s were, incase anyone is interested.
This is what they allowed 15mph HC 84 CO .49 NO 692
25mph HC 49 CO .46 NO 711
First test 15mph HC 6 CO .06 NO 1181 fail
25mph HC 5 CO .05 NO 1400 fail
Then I put in new spark plugs and wires.
15mph HC 1 CO .01 NO 1467 fail
25mph HC 0 CO .01 NO 1444 fail
Then I cleaned out the EGR passage inside the upper intake manifold
15mph HC 13 CO .07 NO 686 pass
25mph HC 1 CO .01 NO 1163 fail
Then I tried some stuff I bought on the internet, some blue sky stuff and also used octane booster.
15mph HC 7 CO .06 NO 659 pass
25mph HC 4 CO .05 NO 1152 fail
After the mechanic did the EGR port cleaning
15mph HC 3 CO .02 NO 429 PASS
25mph HC 0 CO .01 NO 549 PASS
Total cost to get my car to pass this stupid smog check, $640.00
