Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 04-25-2005, 08:44 PM
prod77 prod77 is offline
02 Sierra transmission ?
My tranny was jerking one morning. That afternoon the service engine light came on. I went to Autozone and had a diagnosis done...the code refered to shift solenoid B.
Took the truck to the dealership, I was told that it was the ignition switch.
Is there any way that the two are related???
Thanks in advance!
Old 04-26-2005, 05:08 PM
2000CAYukon 2000CAYukon is offline
Re: 02 Sierra transmission ?
A bad ignition switch or improperly installed remote starter can cause low voltage conditions at the tranny. This can trigger the code for solenoid B.
//2000CAYukon
Old 05-02-2005, 02:39 AM
azphx azphx is offline
Hello, I have a 99 GMC Safari and I'm having solenoid A problem (1-2 shift malfunction--p0753). I got the part from dealer for $22 but I can't find where the unit is to replace it. Could you help let me know where it is located (inside/out transmission)? Do you know if I can change it myself? Please help.
Thanks in advance!
Old 05-02-2005, 01:18 PM
Re: Re: 02 Sierra transmission ?
You have to drop the pan to replace the A or B shift solenoid. This should help: http://www.teckpak-fitzall.com/teckf...ms4l60e_96.pdf
You should make sure the voltage is good at the tranny before replacing it since the ignition switch could also be your problem.
//2000CAYukon
Old 05-02-2005, 02:57 PM
thank you very much..i will give it a try to replace it myself...many thanks...
