Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '93 - '96
Old 04-25-2005, 09:17 PM
jgduffy jgduffy is offline
Question Passat electrical problem fan /wiper /lights
My 1996 Passat TDI has electrical issues. The heater fan, lights and wipers only work when I hit the high beam switch. I can't use low beams or leave highs on. If wiper switch and fan are on they come on when and only when I hit that switch. I'm thinking a ground or switch problem. Fuses look fine. Any thoughts??
Old 04-26-2005, 01:12 PM
boschmann boschmann is offline
Re: Passat electrical problem fan /wiper /lights
Try jiggling & slightly turning the key in the switch & see if that changes things. Ignition switches (electrical part) can cause strange problems as you describe.
Old 04-26-2005, 03:06 PM
Re: Re: Passat electrical problem fan /wiper /lights
Thanks, I'll give that a try. If that is the case should I replace the ignition switch?
Old 11-18-2005, 09:14 PM
Denny G Denny G is offline
Send a message via AIM to Denny G
If youo look around I think you will find a number of ground straps. There might be two on the engine, in addition to the battery ground. I have been told of goofy things like you describe happening when there is a bad ground.
Denny G
Old 11-19-2005, 08:12 AM
Denny G
I swapped out the ignition switch a while back and have had no problem. All symptoms have vanished. I hope I get another 250,000 miles out of her. Thanks
