Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 04-25-2005, 08:06 PM
allencooley allencooley is offline
Unhappy wiring trouble
on my 1977 280e when i try to start the car, it cranks fine but when i let off the key it keeps on cranking,even when you take the key out of the ignition. could someone lend some helping advice
Old 04-26-2005, 05:23 PM
player89 player89 is offline
Sounds like...
a starter relay or solenoid, possibly also the key switch. Is the starter the only thing still running when you turn the key off?
Old 05-01-2005, 01:30 PM
Re: Sounds like...
no, the motor is still turning over.I found some burnt wires, replaced them but still doing the same thing. starter was rebuilt could it be a bad solenoid. check the ignition seems ok. do you know werew i could get a wiring diagram for the ignition system te chiltons manual does not give a good enough break down. thanks for the reply
