Old 04-25-2005, 06:56 PM
mrcrabbiepattie mrcrabbiepattie is offline
what are the pro's and con's to a cold air intake for a 04 silverado??
As the subjesct line said pro's con's for a cold air intake. Will your gas milage get worse or better. Do they really give you that much horse power. Does your right foot get heavier........
Old 04-25-2005, 07:07 PM
TaNK_Em's Avatar
TaNK_Em TaNK_Em is offline
Send a message via AIM to TaNK_Em Send a message via MSN to TaNK_Em Send a message via Yahoo to TaNK_Em
Re: what are the pro's and con's to a cold air intake for a 04 silverado??
So they say you will get improved gas mileage along with some extra horsepower, Id have to agree on that. The more air coming in means the more power.
- Kevin
May God have mercy upon my enemies, because I won't.
- General George Patton Jr
Old 04-25-2005, 10:12 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
And more power would mean you'd push the pedal less, giving you better gas mileage
Old 04-26-2005, 06:32 AM
Nigel215's Avatar
Nigel215 Nigel215 is offline
it will definetly give you better mileage, but that is if you drive normally and dont have a heavy foot like me. I enjoy the extra hp
2000 Silverado LS 4.8, K&N FIPK, Gibson Extreme Dual Exhaust, Line-X Bedliner, Black Speed Grille, Viper Alarm System, Custom Audio system.... (need to update my pic)
Old 04-26-2005, 06:34 AM
jeverett's Avatar
jeverett jeverett is offline
Send a message via ICQ to jeverett Send a message via AIM to jeverett Send a message via MSN to jeverett Send a message via Yahoo to jeverett
I don't think theres any cons to it...none that I can think of anyhow
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-26-2005, 07:28 AM
01Blackerado 01Blackerado is offline
Send a message via Yahoo to 01Blackerado
Some of this is true, some a little mislead!! Mileage doesnt increase you just hit the pedal not as hard, you can do the exact same thing now and increase your gas mileage without changing to cold air!! As a matter of fact the colder the air is the LESS MILEAGE you get!!!! Hot air gives better gas mileage and cold air gives more power!!! (If you need more explanition as to why then id be happy explain)Hope that helps out a little. Oh and there are no cons to it!
Old 04-26-2005, 08:55 AM
then there is the question which one to buy?
Old 04-26-2005, 09:25 AM
No, more power means you would have to push the pedal less to get the same output on the engine, which would give you more mileage because your driving habit would (could) change.
Old 04-28-2005, 10:52 AM
Re: Re: what are the pro's and con's to a cold air intake for a 04 silverado??
NO!!! MORE POWER MEANS YOUR VEHCILE EFFICIENTLY USES THE AIR, FUEL, SPARK AND BURNS IT QUICKLY AND IMMEDIATELY THEREFOR YOU LOSE MILEAGE!!! ONLY CASE WHERE THIS ISNT ALWAYS TRUE IS IN FORCED INDUCTION(TURBO, SUPERCHARGER) ITS BEEN PROVEN TIME AND TIME AGAIN!!!!! TURBOS AND CHARGERS CREATE FRICTION IN THE AIR CAUSING IT TO HEAT UP!!! THE HEAT INCREASES MILEAGE NOT POWER!!!! THE COLD AIR INCREASES POWER NOT MILEAGE!!!! THE MORE COLD AIR YOU HAVE, THE MORE O2 MOLECULES THERE ARE, THE MORE O2 MOLECULES YOU HAVE THE MORE SPARK AND GAS YOU NEED TO BURN IT EFFICIENTLY!!!! OTHERWISE TOO MUCH O2 NOT ENOUGH GAS OR SPARK WILL CREATE KR(KNOCK RETARD) BECAUSE YOU RUN TOO LEAN, HENCE TOO MUCH O2!!!! YOUR MAS AIRFLOW SENSOR TELLS THE ECU THAT THERE IS MORE VOLUME OF O2 BECAUSE COLD AIR NATURALLY CARRIES MORE O2, AND THEN TELLS THE ECU TO OPEN THE INJECTORS MORE TO COMPINSATE FOR THE ADDED O2!!! THEREFOR YOU LOSE GAS MILEAGE!!!
IF WHAT YOU WERE SAYING WAS TRUE, "More power means you hit the pedal less, and get more mileage" THEN EVERY CAR MAKER IN AN ATTEMPT TO MAKE THE BEST GAS MILEAGE CAR WOULD MAKE HIGH OUTPUT MOTORS IN EVERY VEHICLE!! DO YOU THINK THE VIPER GETS GOOD GAS MILEAGE!!??, HOW BOUT THE SS SILVERADO, HOW BOUT THE DENALI, CADILLAC ESCALADE, THE 8.1L SILVERAD WITH 325HP AND 450 FT TRQ!!! WHY IS IT THAT NONE OF THESE VEHICLES WITH ALL THE POWER THEY HAVE, GET GOOD GAS MILEAGE!!! ITS CAUSE IT TAKES MORE O2, GAS, AND SPARK TO MAKE AN ENGINE PERFORM LIKE THAT!!!
Old 04-28-2005, 11:01 AM
Re: Re: Re: what are the pro's and con's to a cold air intake for a 04 silverado??
You lose mileage IF you compare it to having the throttle open the same amount while running it stock. What I am saying is that the truck will make more power with the throttle open less, which will increase the gas mileage if you don't drive like a bat out of hell.
Old 04-28-2005, 11:06 AM
IF WHAT YOU WERE SAYING WAS TRUE, "More power means you hit the pedal less, and get more mileage" THEN EVERY CAR MAKER IN AN ATTEMPT TO MAKE THE BEST GAS MILEAGE CAR WOULD MAKE HIGH OUTPUT MOTORS IN EVERY VEHICLE!! DO YOU THINK THE VIPER GETS GOOD GAS MILEAGE!!??, HOW BOUT THE SS SILVERADO, HOW BOUT THE DENALI, CADILLAC ESCALADE, THE 8.1L SILVERAD WITH 325HP AND 450 FT TRQ!!! WHY IS IT THAT NONE OF THESE VEHICLES WITH ALL THE POWER THEY HAVE, GET GOOD GAS MILEAGE, HELL WHY NOT A TOP FUEL DRAG CAR...THEY HAVE WELL OVER 1000HP AND TRQ!!! ITS CAUSE IT TAKES MORE O2, GAS, AND SPARK TO MAKE AN ENGINE PERFORM LIKE THAT!!! (Repost)
Old 04-28-2005, 01:23 PM
jeverett's Avatar
Man.....drama.
Just get a cold air intake...its all good either way you drive.
1998 ECSB Z71
Whelen LED's
Kenwood 2-way
"BIG 3"
2500+ watt audio
Old 04-28-2005, 01:36 PM
airjam18 airjam18 is offline
I definitely agree with Jeverett.
Old 04-28-2005, 01:58 PM
Try turning your caps lock off
Old 04-28-2005, 02:13 PM
thats it, after all that BS thats all you have to say ..It was on to make it easier for everyone to read!! I wasnt trying to jump down your throat i was just telling you what I've researched in the last 2 years since im doing a 383 CI motor with a GTS76 turbo @21psi and 150 wet shot of N2o. I never meant to belittle your intelligance buy staing what i said!! I just know that I used to think the same way you did! More power meant less gas pedal, which in turn meant less use of gas!! I researched over and over again to find the best possible combo for what i wanted to acomplish (1000+rwhp truck that is still a daily driver) In my research through many people with degrees in this field...this is what I've learned! Once again I didnt mean to hurt any feelings and if i did I appoligize for it!!
