Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 04-25-2005, 05:18 PM
osajay osajay is offline
problem with roof on 1989 lebaron convertable
hi im jay..i have a big problem with my 1989 lebaron turbo convertable..the roof goes down but doesnt wanna come back up ..u can hear the motor of the roof working when i press it to go down ..but wen i press to go back up theres no sound an it doesnt work.i got another swich from the junk yard and it still does the same thing...im sure the motor works to the roof or else it wouldnt go down either .has anyone had this same problem and know what else i can do to fix it .i need help asap my roof is down and its sunny these days but rain is coming soon ..then im in big trouble ..please help
Old 06-17-2005, 05:08 PM
icntdrv icntdrv is offline
Send a message via AIM to icntdrv
Re: problem with roof on 1989 lebaron convertable
It is your motor overheating. It is much easier to lower the top than to raise it back up. To get the top back up in an emergency do this: Get someone to push the up button while you stand in the back seat and forceably pull the top back up.
To fix the problem, either be prepared to spend no less than $800 on a new hydraulic system, or remove the hydraulics completely and go full manual. I removed my system.
Old 07-05-2005, 02:34 PM
troutponds troutponds is offline
Jay:
I had the same problem with my 1992 LeBaron. First check your ground wire to be certain you have a good ground. If that doesn't solve your problem (it didn't solve mine) I bought a rebuilt top motor from a contact I met on E bay. His e mail is [email protected]. He charged me $75.00 for the rebuilt motor and $ 10.00 shipping. I sent my out ona a Friday and had the rebuilt back the following Wedensday. I just finished installing the motor and the top works fine. It takes less than an hour to get the old motor out and about the same amount of time to put the new one in. Hope this helps. Good luck
Old 08-29-2005, 12:23 PM
FordMavGirlLori FordMavGirlLori is offline
Try making sure the valve is fully closed. The valve is located in the trunk. If this does not help I have a used motor and lifts that I can sell you.
Old 09-07-2005, 11:24 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
A little lubercation goes a long way!!
