Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 04-25-2005, 01:30 PM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Phantom Grip LSD and cornering
I'm thinking about getting the Phantom Grip LSD... my only concern is that I want something that'll work on the track as well as on the strip. I'd like to be able to accelerate out of turns. Does anybody know whether the Phanton Grip LSD would make this impossible? Thanks!
Old 04-25-2005, 01:55 PM
Kuhn's Avatar
Also
Also... I've heard that the stock spider gears may bust using the Pahntom Grip... what are the chances of my differential pin going out, too? I don't want to replace my whole transfer case... Thanks!
Old 04-25-2005, 03:03 PM
TreeFrog's Avatar
TreeFrog TreeFrog is offline
Send a message via AIM to TreeFrog
Re: Phantom Grip LSD and cornering
i've heard tons about people blowing trannys with it
Something new is coming...
Old 04-26-2005, 09:18 PM
Kuhn's Avatar
Oh! F that then! I'll just save up for a Quiafe LSD... 6 times the price, but they brag that it'll handle whatever hp u can throw at it... a huge upgrade from using the stock spider gears to jerry rig some LSD... Thanks for the input.
Old 04-26-2005, 09:22 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
check out the magnus dogbox too.
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 04-26-2005, 09:27 PM
clipsekid99's Avatar
clipsekid99 clipsekid99 is offline
Send a message via AIM to clipsekid99 Send a message via MSN to clipsekid99
Definately go with Quaife. I hear it is the best.
2006 Wicked White Evo IX GSR
323 awhp / 311 tq. (Dynojet)
http://www.projectevoix.com
http://www.4WStuning.com
99 RS < 98 GSX < 06 EVO
Old 04-28-2005, 03:27 AM
silver98GST silver98GST is offline
Aren't those Phantom Grips just inserts? I've read the inserts are just temporary fixes and will actually cause damage later. Quaife is the way to go if you want a LSD that is pretty much maintenance free while the Kaaz LSD requires doing figure 8's after installation and fluid change after a period of time. You might also want to check out KarKing's LSDs. They're cheaper than Quaife and they have a good reputation. Quaife is the most popular choice among DSMers. I want to get a LSD installed in my car, but it won't be for a while. How many people have a LSD installed in their car?
1998 Eclipse GST AT
Mods: FP intake pipe, K&N filter, MBC, Glowshift pillar pod w/ tinted gauges (boost, A/F, oil temp gauges), Blitz DTT DC2 turbo timer, Greddy Type S BOV, Apexi N1 exhaust, Megan downpipe, Dejontool blow thru UICP, GM MAFT, Denso 660cc injectors, ARP headstuds, 3000gt sl big brake upgrade, Eprom ecu, DSMlink V2, etc.
Come visit my cardomain page!
Old 04-28-2005, 07:17 PM
FourG63 97GST FourG63 97GST is offline
Send a message via AIM to FourG63 97GST
I've had both.
I'm have pulled similar 60 foot times with each. actually I had the best 60 with the PG. so far anyway. then again this is with 2 different setups.
the quaife corners a whole lot betta than the PG, its not unpredictable.
the reason I went quaife is because I had the tranny apart, so the the hell not, the phanton and diff is on my shelf looking good as ever.
-Agim
