Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 04-25-2005, 12:23 PM
greendayhbt26 greendayhbt26 is offline
Send a message via AIM to greendayhbt26
clutch proglems
when i engage/disengage my clutch there is a squeeking noise..you can only hear it if the engine isnt runing and you are quiet. also, when i start my truck the clutch pedal is loose for the 1st 2 or so inches and then i can feel pressure in the pedal again. after driving for a bit this looseness seems to go away and everything is the way it should be. what could be causing these 2 problems?
Old 04-26-2005, 01:42 AM
amac209 amac209 is offline
Send a message via MSN to amac209
Re: clutch proglems
noise is the release bearing. pedal play may be a few things but if i had to guess i'd say the clutch plate is warped unless the problem is hydraulic
Old 04-26-2005, 11:40 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: clutch proglems
Ever check your clutch fluid?
Resevoir should be driver's side back corner.
I suggest you check the level.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 06-17-2007, 12:30 PM
joes91s15 joes91s15 is offline
Re: clutch proglems
Is the rubber boot still in the resivor ?
Old 06-17-2007, 10:22 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: clutch proglems
this thread is over two years old. please refrain from posting in old threads.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Closed Thread
