Old 04-25-2005, 10:30 AM
Markistrum Markistrum is offline
94 Ford Escort - Engine quits at idle
I have 94 Ford Escort 1.9L 4 cylinder
Car runs great just as long as you are stepping on the gas.
If parked or sitting at a trafic light I have to keep foot on brake
and give a little gas to keep it running. If I do not give it gas
engine sputters a few times and then dies very suddenly.
Can start it right back up with no problem. Its a little odd
that car runs so good while I'm driving. Car runs great on the
highway no problem going over 80 mph and it also sounds good,
no missing when I'm going slower than 10 mph.
I have replaced the spark plugs and wires also replaced the idle air control valve which were very easy- These did not help! Tried running
higher octane gas and fuel injector cleaner, these did no good.
Any other suggestions?
Old 04-25-2005, 11:19 AM
PlayWithGravity PlayWithGravity is offline
I'd suggest maybe buying a Honda. ha haa Just kidding, sorry I can't help! -Marty
Old 04-25-2005, 06:02 PM
A. Souphound A. Souphound is offline
Re: 94 Ford Escort - Engine quits at idle
Possibility the TPS (Throttle position sensor) is faulty or bad connection. The TPS may have a 'dead spot' in the resistor. If you have a DVOM and want instructions on how to check it let us know.
It could also be a vacuum leak such as a PCV valve, or the EGR valve not seated.
Alvin
A PROBLEM WELL DEFINED IS A PROBLEM HALF SOLVED.
Old 04-25-2005, 09:21 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Re: 94 Ford Escort - Engine quits at idle
I think i have seen you post it before but I would like it. Also how to test the IAC vavle. Mine works well when I take it off and spray it then reinstall but then it goes back to "normal" Iw ant to be sure before I pony out $60. for nothing
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 04-26-2005, 08:01 AM
Re: Re: Re: 94 Ford Escort - Engine quits at idle
Hi Chevy
Comment: A defective TPS can affect driveability without setting any codes in the onboard computer.
To check the TPS: Disconnect the harness, set the DVOM to the 20K ohm scale. Connect one lead to the center terminal, and the other to either of the two remaining terminals. SLOWLY increase the throttle watching the meter increase or decrease smoothly as you move the throttle. There should be no glitches or infinite readings...if there are, replace the TPS.
It sounds like your IAC is sticking/galding....they don't get dirty that fast. When you 'clean' the IAC do you put a drop of oil on the pindle end where it goes into the casting? It works for me.
All the best,
Alvin
Old 04-26-2005, 08:34 AM
Thanks for the replys,
Yes, if you can supply the instructions to test the TPS it would
be appreciated. I do own a DVOM to test it.
Buying a Chiltons manual that will hopefully show where this unit
is located
Old 04-26-2005, 01:39 PM
chevyn0va1's Avatar
Re: Re: Re: Re: 94 Ford Escort - Engine quits at idle
Hi Chevy
All the best,
great info alvin only thing I did was spray wd-40 on it should I just try the oil instead? BTW where is the tps on my car I'd like to check mine too. (i have no code on my computer)
Old 04-26-2005, 01:46 PM
is located
See post #5 above for test instructions, and the TPS is located just below the IAC on the throttle body. It's held on with a couple of screws. If you find it is defective and have to change it, I will give you the method for adjusting it back to the correct position.
Alvin
Old 04-26-2005, 04:50 PM
chevyn0va1's Avatar
I just went to go look how the heck do you get in there to test kind need to be a flexable person?-lol
I took the IAC off and hit it with oil like you said and ill see if it did anything. beautiful 65 here and my nova is calling me.
Old 04-27-2005, 11:59 AM
chevyn0va1's Avatar
I did the drop of oil and it seems to work better then the wd 40 did.
Old 07-11-2005, 05:09 PM
Captain Bozo Captain Bozo is offline
I had the exact same problem on my 93, I read somewhere to replace the brake booster, so I got one, stuck it on and it fixed it, mine runs perfect now.
Old 07-11-2005, 05:56 PM
willye willye is offline
My 95 Escort 1.9 did the same thing. I found a hole in the rubber boot that forms an L shape into the intake manifold from the PCV pipe. It costs about $3.00 to get a piece of hose to replace it. Check for any hole in the boot at all -- the system is VERY sensitive to vacuum leaks.
Good luck!
Old 07-11-2005, 07:42 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Thanks for the great tips, guys. My '93 does the same thing. But only seems to do it after the car has warmed up and I shut it off a few minutes and then restart it. Wants to die pretty bad but doesn't.
Nevada Tumbleweed
Old 08-11-2005, 12:08 AM
rmwpm3 rmwpm3 is offline
Send a message via AIM to rmwpm3 Send a message via Yahoo to rmwpm3
I was wondering if you ever found the source of this problem...My car is having the exact same problem; matter of fact, I thought I wrote this message before i saw your name on it...
Please help
Old 08-11-2005, 11:06 PM
Arnoldtheskier Arnoldtheskier is offline
My 93 does this too.Did it when I bought it..new iac etc. Not that bad though.More of the idle getting rougher than actually slowing down that much or stalling.ONLY! when it is warm. Not bad enough for me to chase it yet.I am GUESSING a bad or dirty injector..AS this happens when warm NOT when cold.I am again guessing that it is the injector because it runs so well the rest of the time.Cold there is some sort of fuel enrichment to richen it up.To me it has the symptoms of a drippy injector.I guess I could try and isolate it to a particular cylinder..but I haven't botherred.At one time I thought of taking off the t.body and doing what I have to do to to get the screw(factory set) so that I could adjust the idle normally.This woulld raise it slightly when warm..not sure how much when cold.BETTER idea is to get another t body and fiddle wirth that one.BEST yet is to make a tiny little bracket and have ANOTHER place to control the idle.Drill and tap for another little bolt or screw.I spend almost no time idling anyway that it is not a big enough deal to think too much about.Guess I could also do a cold and hot fuel pressure.Mine has good eng. vac cold and hot(same).Oh well.
