Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 04-25-2005, 09:36 AM
scoutinkeith's Avatar
scoutinkeith scoutinkeith is offline
Send a message via AIM to scoutinkeith
check engine light, and code
the truck is a 99 1500 4x4, w/ 5.9, and auto trans. the check engine light came on last week, was on for about two days, then went off. this weekend I took it to autozone and had it checked for codes.
it had a p0443 ( I think that's the correct number, I lost the paper that I wrote it on) anyway, the guy said that it was the "purge valve C". dose anyone know where that would be located, and if it is something that I can pick up at any parts store, or do I have to go back to the "stealership" to get it?
thanks,
Keith
when all else fails, get a bigger hammer.
Vehicles:
2005 suburban 1500 4x4
all stock, ex-fire department truck.
1987 Grand Wagoneer
Old 04-25-2005, 10:21 AM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: check engine light, and code
Something for EGR? Does that sound familiar?
The EGR system has a purge solenoid comprised of valves apparently.
My Mopars
Old 04-25-2005, 12:48 PM
the guy that scanned it said that it was part of the evap. emission system. I thought there was only one purge valve, on the evap canister, but apparently there are several in the evap system, I'm just not sure which one is purge valve "C"
Vehicles:
1987 Grand Wagoneer
Old 04-25-2005, 07:28 PM
1thunder 1thunder is offline
there is a purge solenoid on the passenger fender just behind the headlamp assy there is 2 hoses going to it and one 2 wire connector white/black tracer wire and a pink/black tracer wire now you must make sure what code you have as there are many evap system codes and fault and many different repairs this is somewhat more complex than you may think especially if your not using the right code to diagnose
Old 04-26-2005, 09:31 AM
sense the check engine light has gone away, do you think it's worth it to take it to the dealership to have it scanned again? and would they be able to narrow down what the problem is, or is it not worth bothering with unless the light comes back on?
by the way, thanks for all your help,
Keith
Vehicles:
1987 Grand Wagoneer
Old 04-26-2005, 11:25 AM
kkirby kkirby is offline
First problem is the "auto zone" scanner. It is a very basic scanner. Go to a reputable, trusted repair shop, not the dealer who has a computer for total scans. They should be able to pinpoint your problem with a great amount of certainty. Also the fix will be much cheaper than the "stealership". Good luck!
Old 04-26-2005, 06:00 PM
i would wait and see if the lamp comes back on
Old 04-27-2005, 11:19 AM
thanks,
I've only driven it a few times sense the light went off, and all seems to be ok. but if it dose come back on, then I gues I'll just take it in to the dealership.
thanks again for all the help,
Keith
Vehicles:
1987 Grand Wagoneer
Old 05-03-2005, 04:41 AM
Klaz28 Klaz28 is offline
Wasn't sure if you knew how to retreive your codes but on any dodge chrysler you turn the ignition on and off three times(don't start the vehicle) then it should give you flash codes or display the code in the odometer.
Atleast Ford knows how to circle their mistakes!
Old 05-03-2005, 12:17 PM
klaz28,
thanks for the info, but actuaily, that dosn't work on my truck. the key thing worked on the "old" OBD systems, but when they switched to OBD II, which I belive was in 97 or 98, you could no longer retreive the codes by turning the key on and off. and sense my truck is a 99, turning the key on and off dose not show codes.
thanks anyway,
Keith
Vehicles:
1987 Grand Wagoneer
Old 05-03-2005, 04:36 PM
Austin8214's Avatar
Austin8214 Austin8214 is offline
Re: Re: check engine light, and code
Originally Posted by scoutinkeith
klaz28,
thanks anyway,
Keith
The key trick worked on my 97 so it must have been 98. Are you sure you are doing the key trick right. You must turn it on off on off on in three seconds. If that does not work let me know because i have never heard that the key trick does not work on the newer stuff. My father-in-law has a 98 1500 i will see if it works on his.
Old 05-03-2005, 06:48 PM
jrmcx jrmcx is offline
Key trick works on my 2001 ram. Odometer in trip mode, on / off ingnition three times.
Old 05-04-2005, 08:25 AM
"Key trick works on my 2001 ram. Odometer in trip mode, on / off ingnition three times."
maybe that's why it didn't work when I tried it, I was not aware that the odomoter had to be on the "trip" setting. thanks for the info, I'll try it again tonight when I get home, and let ya know if it works.
Vehicles:
1987 Grand Wagoneer
Old 05-04-2005, 10:38 AM
DCDodge DCDodge is offline
Obviously, your truck must have the digital odometer, huh?
DCDodge
Old 05-05-2005, 02:33 PM
Yes, but if yours don't it should give you "flash codes".
