Old 04-25-2005, 09:28 AM
riff22 riff22 is offline
coil pack
does anybody know how to check a coil pack?
-1995 Eagle Talon TSI AWD
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-walbro 255 fuel pump
-550cc injectors
-pocketlogger
-2.5 full exhaust (no cat)
-30 psi bov
Old 04-25-2005, 10:45 AM
team_apocalypse team_apocalypse is offline
Send a message via AIM to team_apocalypse Send a message via Yahoo to team_apocalypse
Re: coil pack
you got spark on all four cylinders? if so, coil's good.
Old 04-25-2005, 10:46 AM
Re: coil pack
so it either works or doesnt, you cant have like less spark to one plug?
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-25-2005, 12:46 PM
Re: coil pack
I'm having an idle/stalling problem with my 95 Eclipse and what I was told is that if their is spark on all four, the coil is fine. But that if the altenator is bad or weak, the spark will be weak. I'm down to my last few options before replacing eveything again.
Old 04-25-2005, 01:03 PM
Re: coil pack
mine idles fine just has a pop in the exhaust and seems to miss a lil, jerks, not real bad you cant really feel it unless you pay antention , i have new wires to put in yet. alternator is my last guess.
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
Old 04-25-2005, 09:54 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: coil pack
To answer the question, there are some tests you can do with a voltmeter. Most repair manuals should have the procedure. The factory manual definitely does.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 04-25-2005, 10:10 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: coil pack
have you tried replacing the plugs yet? don't use platinum plugs.
95 Talon TSI AWD
97 Eclipse GST
Old 04-25-2005, 10:13 PM
ned032002's Avatar
ned032002 ned032002 is offline
I know that on my car there is a plug connection that supplies the coil pack with the power that it needs. The plug has 3 prongs in it
( [1] [2] )
( [3] )
If you test 1 and 3 then there for cylinders 2 and 3, test 2 and 3 and there for cylinders 1 and 4. My book says this and I'm quoting it "Compare reading to the desired primary coil resistance of 0.70-0.86 ohms. Measure the coil secondary resistance as follows Measurethe resistance between the high-voltage terminals for the No.1 and No.2 cylinders, and between the high-voltage terminals for the No. 2 and No.3 cylinders. The desired secondary coil resistance of 11.3-15.3 kilo-ohms. If the readings are not within the specified value, replace the ignition coil."
I don't know if this helps at all because the years are different between our vehicles so thats all I can really help you with. I looked at my manuel but it doesn't support the year of your car. Good luck and get a Repair manuel, I suggest the Chilton's Repair Manuel thats the repair manuel I got that info from.
Old 04-26-2005, 07:33 AM
Re: coil pack
i put ngk plugs in but there the dual exectrode
-5 speed
-evo 3 GT
-SAFC 2
-NGK Plugs
-550cc injectors
-pocketlogger
-30 psi bov
