Old 04-25-2005, 09:06 AM
4500 4500 is offline
Turn up 7.3 Diesel
There must be a way to trick the computer into letting the fuel pressure come on sooner, in the big truck motors you can adjust the air valve, any way to ajust the MAP?
Old 04-25-2005, 09:03 PM
yotermanic yotermanic is offline
I don't reccommend any of these, but I've seen people do these in the dealership and swear by them. You can disconnect the MAP and ignore the engine light. If the truck doesn't detect boost, it keeps upping icp and fuel pump duty cycle. I've also seen people put ball bearings (small ones!) in their regulator on the downstream side of the poppet to hold it a little tighter than the spring.
Old 04-26-2005, 09:08 AM
Re: Turn up 7.3 Diesel
can you explain , what is a poppet? where is the regulator?
