Old 04-25-2005, 08:11 AM
lexus4jie lexus4jie is offline
Question Why Is The Fuse Panel So Different For Fuse #6??
99 WINDSTAR LX FUSE QUESTION: WHY IS THE FUSE PANEL SO DIFFERENT FOR FUSE #6?? I WAS ABLE TO PUT A REGULAR MINI-TYPE FUSE IN, BUT IT WAS WAY DEEP WITHIN A "LONG SQUARE CHANNEL" ON THE FUSE PANEL. IS THERE A SPECIAL TYPE OF FUSE FOR THIS #6 SLOT? I had to use needle nose pliers to push it in, and I pity the guy who ever has to remove it. It must be an INCH in there!!
Sorry, this question is related to my previous thread but I wanted to have a separate subject header for this topic instead of adding it to that thread.
Old 04-25-2005, 02:21 PM
12Ounce 12Ounce is offline
Re: Why Is The Fuse Panel So Different For Fuse #6??
Fuse #6 is supposed to have a special plastic clip "handle" that allows fuse #6 to be pulled out slightly into a disconnected position. The glovebox handbook explains that it is to be pulled into this position for periods of extended parking.
Supposedly helps prevent battery death during such periods.
Old 04-26-2005, 07:37 AM
Thank you, "12 ounce". But I have no glovebox manual and the fuse is missing. Auto parts store or Dealer? What size fuse please?
Old 04-26-2005, 12:00 PM
See if you can open up the following and print out your glove box manual ... its a flaky site, sometimes it works just fine, sometimes not:
http://www.genuineflmservice.com/default.asp?page=E4
