Go Back   Automotive Forums Car Chat > Ford > Econoline
Old 04-25-2005, 08:00 AM
targetman targetman is offline
Diesel won't start
I got into my van this morning and it won't start. It's a 91' E350. The engine is turning over and there is fuel in both tanks. The fuel filter was replaced about 10,000 miles ago. The van has 155,000 miles. I don't think it's getting fuel as it's not attempting to fire. The weather this morning is 34 degrees with a wind chill of 23. It coulnd't be gelled, could it?
Old 04-25-2005, 12:44 PM
ModMech's Avatar
ModMech ModMech is offline
Re: Diesel won't start
Glow plugs. This engine will NOT start below about 80*F if the glow plugs do not work properly.
It is possible that the fuel solenoid is either not getting power, or that it is bad (VERY unlikely). You can chack for power at the large wire on top of the fuel pump (driver's side) with the key on. If you have power, crack an injector line open (5/8" open end wrench), and crank it over some. If you get fuel out of the line, your glowplugs are the problem.
At 35*F, two bad plugs will prevent the engine from starting if it is in GOOD shape, if it's suffering from miles, time, or poor maintence, even one inoperative glowplug could prevent it from starting. This is NOT because you need all 8 cylinders, but because the GP controller uses the resistance of the glowplugs (all of them togather) to figure out how long to stay on, the more you lose, the shorter a time the plugs remain on, so they do not get up to temperature.
The Following User Says Thank You to ModMech For This Useful Post:
clutch492 (08-26-2011)
Old 03-06-2010, 09:45 PM
storm13 storm13 is offline
have you changed your oil lately all powerstrokes fuel systems run on a oil pump if your oil loeses voscity meaning it gets too thin the pump loese prime and your fuel system will not work
just infront of yourfuel filter on the top of the moter there is a plug with a 3/8 drive square hole open and fill with oil and it will fire right off
Old 05-12-2010, 11:35 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
91 would be a IDI 7.3 not a Powerstroke... So its got an Injection pump, not HPOP.
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
