Sunroof
I have a 1995 sc2 and my sunroof's off the track (the track is broken) on one side. My father and I are going to replace it because it leaks horribly and it won't open. Any suggestions to make this an easy fix? We live by a junk yard that has everything we'd need.. Thanks.
Re: Sunroof
search saturnfans.com
Aren't there little plastic clips in there that are known to break and cause it to come out of the tracks? ... someone correct me if I am wrong ... also, make sure your drain line is blown clear as far as the leaking goes too.
Re: Sunroof
my sunroof has a hard time coming up but with a little push it will pop up and slide as well as fully close on its own. what could be causing this problem?
Re: Sunroof
have the tracks been lubed lately?
Re: Re: Sunroof
i sprayed them with some wd-40 i dunno if that was the right stuff to use but that helped but has been about 2 weeks and its doing it again
Re: Sunroof
WD-40 is not the right stuff, use white lithuim grease
Had the same issue on my 91 SC when I got it. I removed everything. took a wire brush to the rusted/corroded metal. greased the track, cleaned EVERYTHING with carb cleaner (the plastic safe type) and put it all back,, now it glides like butter.
