No code flashing and still have.........
idling issues??
I was having a code 33 for the MAF sensor. It has gone away and not returned (yet anyway). I have new plugs, wires and dist cap. I have checked all over for vacuum leaks and not found any. It seems to get worse as it warms up. It has great acceleration. It want to die when I stop at a light so I am having to ride the brakes to keep it running. When it dies after being warmed up, sometimes it struggles to turn over (acts like timing is advance too high?). I have been thru all the basics like trying to figure it out including the TPS calibration. Any suggestions? |
Re: No code flashing and still have.........
Grand National. Going fast with class. Voted FASTEST street car on AF. Here is the proof!!! 1987 Buick Grand National. Back in action!!!! 1999 Ford F-250 Tow rig from hell 598 Ft-lbs. ASE Certified in... Mobile AC On Highway medium duty diesel engines. Off highwayy medium duty diesel engines. On highway trucks. Working on the eletronics certification Member ofA.A.N.B.C- Afer against non boosted crews #2 |
It is an '87 Iroc with 5.7 TPI.
Ok I have a $2 dollar(hopefully it will work) fix for you. You just need a can of brake clean.
First make sure the car is completely shut, no key on either. Then unplug the MAF, unscrew the 2 hose clamps, and completely remove the MAF from your car. If you look inside the MAF you will see 1(maybe 2) resistors in there. They should be completely clean. Simply spray them with the brake clean(a couple short burst is sufficient) and let it air dry. Do not try a brush or anything else to clean them, they are very fragile and likely to break. This MAF is a hot wire sensor. When more air is introduced onto those 1 or 2 resistors it cools them down slightly, in effect, varying the amount of fuel into the combustion chamber. If they are contaminated, the dirt can act like an insulator, not allowing them to cool. I'm not saying this is a deffinet fix, but it is a cheap guess. |
yea lets spray some very sensitive wires with brake clean.... NEVER ATTEMPT TO CLEAN YOUR MAF!!!! unless you like to go spend money on them.
Jonsonton, have you tried this test before yourself? What if I unplug the MAF and then start the car? If it was a bad sensor, would it not react differently right off?
Also, this car doesn't have the air box attached. How does this impact the operation of the MAF? I hooked up a single element filter to the MAF for testing but didn't seem to help out. I don't know if I didn't let it run long enough or what. |
Re: Re: No code flashing and still have.........
When you say, a single element filter, are you reffering to a K&N cone type filter. If so, this should not effect the system that much. |
Yes, it was a cone type filter. I wasn't sure if the filter restriction had much bearing on the MAF operation.
I already did the test of unplugging the MAF but I have since then reset the computer. I will try out your test and see what happens. Thanks! |
