Old 04-25-2005, 12:32 AM
v8blakdak v8blakdak is offline
engine knock problem
hi, we have a 99 dodge caravan 3.0L with 85k miles. the engine knocks upon start up, i was wondering if this is common, and if its the valvetrain, could it be a bent pushrod or somthing.
also the belt has one less rib bc it gets torn up. after it gets torn up, it works fine. are the pullies misaligned? we had the tensioner pulley replaced and still same problem. thanks
Old 04-25-2005, 02:58 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: engine knock problem
You say that the engine knocks, what does it actually sound like. Is it a mild tic tic tic or a metal to metal knock? One is no problem the other can be very expensive. Is the noise constant or only at start-up? If it goes away and it is a tic then it is probably a lifter that has leaked down, nothing to worry about. If it is a heavy metal knock you could have a rod bearing ready to go out or a rod ready to break. I would bet on the valve lifter!
Old 04-25-2005, 03:12 PM
thanks, it is kinda louder then valvetrain noise, but it does go away after 5 mins. i hope its just a lifter.
thanks
Old 04-25-2005, 08:30 PM
EVH5150 EVH5150 is offline
My 94 3.0 does that occasionally too, especially in cold weather. It's done that ever since we bought it in 1997. Someone told me it's common with these motors, but other than the ticking which goes away after a few minutes, the motor runs really good.
