Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-25-2005, 12:12 AM
kenc195 kenc195 is offline
Question oxygen sensor code PO135 & misfire in #5
Just had my code checked since the check engine light was flashing. I have an o2 sensor heater failure but couldn't tell which bank it is from. Any ideas.
Also, having misfire in #5.(rt rear cyl) No idea how old the plugs are and thinking of changing them all. OEM is platinums at about 9.00 a pop right?
I just bought this truck and have no prior maintenence information. I am a reasonably skilled DIY but hate taking chances with my only transportation and limited budget. Sometimes it is cheaper to pay a pro. Is their any tricky work here?
97 passport with 142,000 on it
Life is good with my 97 Passport
Old 04-25-2005, 07:58 PM
rodeo02 rodeo02 is offline
Easy one. P0135= O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1) That's the driver's side, before the catalytic converter O2 sensor. As far as the cyl 5 misfire goes?, I'd start by examining the spark plug boots & plugs. Your 1997 should run fine in NGK's, but for sure it will like denso plugs (www.sparkplugs.com)
G/luck!
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 04-25-2005, 08:29 PM
surferfletch surferfletch is offline
Re: oxygen sensor code PO135 & misfire in #5
Diy!
Old 04-26-2005, 06:25 AM
Canucklehead Canucklehead is offline
Send a message via MSN to Canucklehead
G/luck!
Joel
Bank 1 is passenger's side...
2000 VW New Beetle TDI
2007 Honda CR-V
Old 04-26-2005, 11:20 AM
Alright, we have a tie. One says driver side, one say passanger side. What says you?
Old 04-26-2005, 11:52 AM
Re: Re: oxygen sensor code PO135 & misfire in #5
Odd cylinders (1,3,5) = Odd Bank
Even cylinders = Even Bank
2007 Honda CR-V
Old 04-26-2005, 06:02 PM
wreck05's Avatar
wreck05 wreck05 is offline
Bank 2 is definitely the Driver's side! I found out the hard way. But you should probably replace both at the same time anyway. If one is bad, the other will probably also go soon. It can only help your performance to do so.
Old 04-26-2005, 07:43 PM
Originally Posted by wreck05
Bank 2 is definitely the Driver's side! I found out the hard way...... .
Oooops ! You are absolutely right! Bank one is the passenger side, bank 2 = drivers! Sorry fellas.
G/luck
Joel
Old 04-27-2005, 12:02 AM
I stiopped on the way home tonight and figured, what the heck and bought 2 of the sensors. I plan to replace them tomorow and will let you all know how it went.
Can you believe Autozone didn't have NGK or Denso (sp?) plugs. Napa here I come
Thanks for all the input here
Old 04-27-2005, 08:09 PM
........Can you believe Autozone didn't have NGK or Denso (sp?) plugs. Napa here I come
NGK's are hard to find. You can usually find them only at motor-sport or import specialty shops. Denso's are near impossible to find locally. Try www.sparkplugs.com
G/luck
Joel
Old 04-27-2005, 08:15 PM
superfret78 superfret78 is offline
You'll have more luck at Advance Auto Parts for parts on these cars. Advance carries NGK's.
Old 04-28-2005, 05:03 AM
Tom01Rodeo Tom01Rodeo is offline
O'reilly carries NGK also.
Old 04-28-2005, 02:30 PM
Napa had only had bouch and I had to go to 2 stores to get 6. I changed the preconverter o2 sensors and that only took an hour including one trip inside for a band aid. (no job is complete without shedding some blood).
The big problem is I still have a misfire in #5. This is a 97 V6 so it has the coil packs on each plug. Can those be tested with a ohm meter? Any other suggestions BTW the Bousch are platinum OEM recommended but were only about 2.95 ea. I was expecting 6.00 or so.
Old 04-28-2005, 02:54 PM
amigo-2k amigo-2k is offline
Isuzu Guy
I think you can just move the coil pack. if the misfire moves with the coil pack then I think you can say it is the coil pack.
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 04-28-2005, 04:23 PM
I moved the coil pack from #5 to #3 and the misfire went from #5 to #3. Hmmm I think we have a bad coil pack here. These are not very common parts and their is only 1 in the Phoenix Metro area (population 3.5 million). Thats at an Isuzu dealership $123.00. Honda (it is a Passport) has 1 600 miles away. Aftermarket shops were all special order $100-$130.00 range.
