Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 04-25-2005, 01:01 AM
rebuild_king rebuild_king is offline
Thumbs up fixed super loud knock 96 rodeo 3.2 v6 6vd1
my rodeo had a slight tick when i bought it with 90 K on it aroung 110 K
while going down the freeway about 70 mph it started to sound like a slegde hamer pounding on the passanger side (Right Bank) valve cover
not knowing any thing about cars i found this forum and thought it might be the timing belt tensioner so i tore into it and replaced it it did not fix the prob so i took apart the top end (pain in my ass) i didnt see any thing wrong so i took off the head to see if i had bent a valve it looked fine then i took the camshaft off to inspect it and found the hydraulic valve lash adjuster was shoved up into the rocker arm on 2 intake and
1 exhast rocker replaced at $70 a pop belive it or not the delear was the cheepest put it all back together and started right up the knock was gone on the passanger side (Right Bank) allowing me to hear the knock on the driver side (Left Bank) so now im going to tear it down for the
4th time and hope its not more then 3 also i'v been told that you can rebuild the hydraulic valve lash adjuster but it's a major pain in the ass
ill let you all know how the other side goes
ps i do interior mods on the poor man's budget and it looks professional
ill be posting some walkthroughs on topend engine repair and how to's on mods.
Old 04-25-2005, 07:22 AM
superfret78 superfret78 is offline
Yeah...I have a similar problem. I am about to tear into my 94 3.2L as well.....its gonna be fun, I can tell already.
Old 04-26-2005, 10:06 AM
new_93_owner new_93_owner is offline
please repost i have a 93 with 162000 and am having the same problem
i read a couple of dif' post they were leaning to the timing
Old 04-26-2005, 02:45 PM
siezed engine
this moring i was warming her up to check it out and the tick came back
so i drove it around the block trying to get some oil up into the rocker arms and it sounded like marbles clunk clank thump and it stoped i had to have it towed back i read a posting about a spun #1 bearing i don't know if im going to fix this motor or burn the f***ing thing it have put 1,500 + into the motor and about 500 into customizeing the interior
just to open it cost gaskets at 20 a pice this will be the 5th time if i choose to embark on this endevor isuzu can take this engine and shove it i might swap with a motor / tranny/ wireing harness / pcm from a toyota or honda at least there not affilated with G.M. for educational porposes i may post step by step high res color photos on the tear down
/rebuild ??????
{{{{{{{{{{{{{{{{{{{{{{ATTENTION}}}}}}}}}}}}}}}}}}} }}}}}}}}}}
To all isuzu owners if you hear a slight tick in your motor check the oil and then use one of the remadies found on this site ATF oil additives use conventional oil after engine flush light weight oil if it is knocking remove timing covers if it is still knocking its rocker arms / spung bearing
basicaly time for a new motor dont waste mony like my unless you have a machine shop and engine hoist and stand
Old 05-03-2005, 08:37 PM
lazyone lazyone is offline
Did the noise almost make the engine sound like a loud diesel?
My '94 3.3 V6 Rodeo is making a similar noise.
Reading the posts, there is no real fix for the problem other than major engine surgury?
Old 05-19-2005, 05:50 PM
Re: fixed super loud knock 96 rodeo 3.2 v6 6vd1
yes i have found out it is ini the lower part of the motor it needs to swaped out for a new / used motor
