Go Back   Automotive Forums Car Chat > Ford > Focus | C Max
Old 04-24-2005, 11:05 PM
bigjordan04 bigjordan04 is offline
turbo on high mileage engine?
I have a 2000 zx3 with around 100000 miles on it. I was wonderng how bad of an idea it would be to turbocharge an engine with that many miles on it. I figure it would be best to completely rebuild the bottom end but the cost of that combined with the turbo kit would be quite expensive.
Old 04-25-2005, 09:52 AM
backyard_mech420 backyard_mech420 is offline
Turbocharging is always a good thing,but on higher mileage engines the higher than stock cylinder pressures caused by forced induction will eventually Blow your Head Gaskets.I found this out the hard way on my Car.If you are planning an engine rebuild or replacment sometime in the future then this is not a bad idea,but if you want this car's engine to last for awhile then I would'nt turbocharge it.
Old 04-25-2005, 02:50 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
if your going to pay at about $3500-4000 for a turbo kit, I wouldnt skimp on the engine. At a bare minimum, I would replace the pistons and rings.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 04-25-2005, 05:15 PM
Mustangman25's Avatar
Mustangman25 Mustangman25 is offline
Send a message via AIM to Mustangman25
Re: turbo on high mileage engine?
Agree...not only will the stock parts not last as long, but it's also a good idea to get new low compression pistons with a turbo kit, stronger rods too...it's sort of like buying a bodykit without having the money to paint it...you have it, but you can't get the full advantages out of it.
-Chuck
