Old 04-24-2005, 09:29 PM
Leesmack Leesmack is offline
main relay problem??
car starts fine but when i take off and slow down to take corners or stop at stop signs ill down shift(sometimes even when i dont but when i slow down)the car feels like it is dying(no gas) ill keep my foot on the gas pedal all the way down and it wont move but after like five seconds it starts to sputter and take off and its all good till i stop or slow down at a corner??
but 2 days before this started happening i was driving and i thought it ran out of gas and it might cause i was low on gas, it died and i couldnt start it but it was trying to crank over but not getting gas then i remove air filter tube from the intake(injector area) and put a rag with gas in there and it would start for a few seconds then die when removed it.
i had someone look at it he said main relay overheated or something but then all the stuff at the top of this thread started happening. then tonight it died again on my friend and not able to start??
please reply hope not too long of thread thanks all
Midwest Meet in Saint Louis this Spring 2005!!!!
1st Midwest Meet
90 honda civic hb 4 spd manual
short throw shifter
ngk platnium plugs and wires
castro synthetic oil
Old 04-24-2005, 11:16 PM
Kven's Avatar
Kven Kven is offline
Re: main relay problem??
well when i had the main relay problem, the car wouldnt turn on at some times(the main relay wasnt switching the fuel pump on), but once it got started everything was ok.
i also had a o2 sensor problem, when i would drive on the highway and would have to slow down and accelerate again, the car would shake and such like it was running out of gas.
have you check the ECU for any codes?
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 04-25-2005, 12:43 AM
Hilikus Funkin's Avatar
Hilikus Funkin Hilikus Funkin is offline
Send a message via AIM to Hilikus Funkin
maybe ur fuel pump is dying or your injection is clogged?
1991 Honda Civic DX Sedan
Old 04-25-2005, 10:15 AM
honda_luvr_2000 honda_luvr_2000 is offline
try filling u'r tank all the way and see if the problem persists. could be low on fuel and be cutting out from sloshing in the tank.
Old 04-25-2005, 02:07 PM
new fuel filter and pump
but they found the problelm and it was main fuel relay he said it cost 70 bucks for it though
1st Midwest Meet
short throw shifter
